Author Topic: trouble shooting my k7000  (Read 1772 times)
lenub
  • Last login:January 02, 2012, 06:23:06 pm
« on: December 23, 2008, 12:49:03 pm »
I have a k7000 in a cbinet with a 1000-1 board
had the  k7000 recapped due to dark half of the screen. I got it back and put it in and worked great .
  Now no picture but sound ... the board is powered from another source from the k7000
so if I turn the power off to the monitor with 1000-1 still powered I see the game screen for a second as the monitor turns off.
   any ideas before I start ripping into this
      thanks
Ken Layton
  • Guru
  • Technician
Re: trouble shooting my k7000
« Reply #1 on: December 23, 2008, 01:18:48 pm »
Bad solder joints maybe. More likely the B+ regulator IC has gone bad. It has an STR number on it. Replace only with the same type number or it's equivalent.
It will be one of these four numbers:
STR3130
STR30130
STR3123
STR30123
Most of those cross over to NTE brand replacements.
If it had an STR3130 then you need an STR3130 or it's NTE equivalent.
lenub
« Reply #2 on: February 08, 2009, 03:27:18 am »
got my STR30130 from bob roberts and changed it out and now I have a picture BUT it doesn't fill the whole screen (it did before) tried to adjust everything but no go only fills 85/90 of the screen
 any thoughts
Arm123
  • Last login:March 03, 2025, 11:26:20 am
« Reply #3 on: February 10, 2009, 09:42:40 am »
pic ?..
