Author Topic: CABMAME: frogger hack question  (Read 2246 times)
shiloh
  • Last login:May 10, 2016, 02:58:07 pm
« on: December 05, 2008, 07:01:20 am »
Hello
I have compiled cabmame .128. I installed it on my cabinet and it works very nice. However, I cant get the frogger hack to work; frogger 9or other galaxian hardware based game) is trying to run at 768x224 and it end up being stretched on my cabinet.
I use an arcadeVGA with a standard res WG. GameEx is my front end.
Mame is configured to ddraw, no hwstretch and tripplebuffer is on. I have no frogger.ini with specific resolution.
the ArcadeVGA option in Gameex is on (dont know if it has an impact).
anything thing else I need to check or try?
thanks in advance!
Marc
bent98
  • Last login:February 02, 2019, 03:35:00 pm
  • Hyperspin Moderator
Re: CABMAME: frogger hack question
« Reply #1 on: December 05, 2008, 08:15:19 am »
You need make a frogger.ini file and add these 2 lines
resolution 352x264
switchres 1
shiloh
« Reply #2 on: December 05, 2008, 09:22:04 am »
thanks I'll try that tonight.
switchres is already enabled in my mame.ini so I cant take it out of the frogger.ini right?
bent98
« Reply #3 on: December 05, 2008, 01:09:07 pm »
yes
I noticed you had  tripple buffering turned on. I wouldnt use that unless your having tearing problems on certain side scrolling games. Try it with and without.
