Author Topic: CPS2 A Board blew my Monitor  (Read 4666 times)
SomeDJ
  • Last login:April 04, 2010, 07:40:40 pm
« on: October 29, 2008, 01:03:35 am »
So I was testing my 4 A boards to see if any were dead as I had never plugged them in before. I plugged in the second one and maybe 10 seconds after flicking on the power I hear the fan spin up really fast and I hear a snap and my monitor is gone. Has anybody ever heard of this before? I was running a Jrok board into a 19" Samsung TV. I checked my PSU and it seems fine. My Jrok board seems fine except for the LED which I'm sure blew. Not sure about the B board that was in the A board. I'll have to test that later. The fuse on the TV's chassis is fine but I can't read any voltage across it. Anybody seen or heard of a similar experience?
Re: CPS2 A Board blew my Monitor
« Reply #1 on: October 29, 2008, 09:42:32 am »
That would be extremely odd for your board to blow your monitor, I would think.
CPS2 motherboard fan spins very fast and loud normally.
grantspain
« Reply #2 on: October 29, 2008, 02:11:20 pm »
would not affect the monitor,most likely is that you have a power supply fault
you need to set your multimeter to dc volts and read the jamma connector at pin 1(ground-black meter probe) to pin 3(+5-red meter probe)
SomeDJ
« Reply #3 on: October 29, 2008, 02:25:57 pm »
I've checked my power supply and it's fine. Not sure how I'm gonna track this one down. Would it be possible for a fault in the A board's video circuit to send a surge to the RGB or maybe a fault in the boards power circuit sent a surge to my power supply and there was a momentary spike in voltage?
grantspain
« Reply #4 on: October 29, 2008, 02:31:40 pm »
turn up the screen volts to see if you get a white screen
SomeDJ
« Reply #5 on: October 29, 2008, 03:02:22 pm »
the screen no longer powers up
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« Reply #6 on: October 29, 2008, 03:34:19 pm »
It's just a fuse.
NO MORE!!
SomeDJ
« Reply #7 on: October 29, 2008, 03:53:35 pm »
The fuse is fine as I stated in my original post. I tested continuity across the fuse and it's fine
Kevin Mullins
    • Me on Myspace
« Reply #8 on: October 29, 2008, 03:58:20 pm »
It's just a fuse.
:laugh2:
Across it ?
You don't measure voltage across the fuse, as in end to end of the fuse.
You measure it from one leg of the power cord to either end of the fuse.
Do you still have power coming in at the power cord of the TV/monitor?
SomeDJ
« Reply #9 on: October 29, 2008, 05:23:22 pm »
That's what I meant by across it.
I found a loose cap on the chassis and resoldered it to the board. I looked for other cold solder joints and found nothing.
Still no monitor though but I do have power into the board and through the fuse.
« Last Edit: October 29, 2008, 05:34:06 pm by SomeDJ »
Kevin Mullins
    • Me on Myspace
« Reply #10 on: October 29, 2008, 05:37:03 pm »
What is the make/model of the monitor?
SomeDJ
« Reply #11 on: October 29, 2008, 05:45:00 pm »
It's a 19" Samsung TV. Not sure of the model though as I threw the casing out monday and recycling pickup was yesterday.
qrz
  • Last login:October 24, 2015, 03:04:15 pm
  • wrangling electrons since 1978
« Reply #12 on: October 30, 2008, 06:32:00 pm »
there should be a make/model/serial number tag on the tuner shield - pending age of unit
qrz
Ken Layton
  • Guru
  • Technician
« Reply #13 on: October 30, 2008, 06:48:19 pm »
Sounds like the tv has a "hot chassis" design.
SomeDJ
« Reply #14 on: October 30, 2008, 06:59:12 pm »
No need anymore. I threw it out and found a free one off of craigslists list. Just putting it in now.
SomeDJ
« Reply #15 on: October 30, 2008, 09:48:13 pm »
Must've been something else. This new monitor looks great. Even with a Jrok board and using composite. I tested all my A and B boards and they're all good except for one A board which has no sound.
grantspain
« Reply #16 on: October 31, 2008, 03:46:15 am »
i think the monitor just went faulty,just bad timing i think
SomeDJ
« Reply #17 on: November 01, 2008, 08:14:06 pm »
I'm thinking the same thing now. It was all just bad timing. Everything's going good now. Cab's almost done.
