Poll
Which works best for you
Horizontal
1 (25%)
Vertical
3 (75%)
Total Members Voted: 4
Author Topic: Lcd Top Gun Mounting: Horizontal or Vertical  (Read 2671 times)
Shieldwolf
  • Last login:November 16, 2020, 12:48:53 am
  • SpearShield.com
« on: October 18, 2008, 12:37:46 pm »
I'm using a 27 inch WG monitor. I can't actually use the gun as my cp is currently missing (see other thread), but I wanted to see what the consensus was on mounting in your arcade cab.
Turnarcades
  • Craig @ Turnarcades
    • Turnarcades
Re: Lcd Top Gun Mounting: Horizontal or Vertical
« Reply #1 on: October 18, 2008, 03:17:19 pm »
Although horizontal would be arguably easier to conceal, I've found they do work better vertically.
« Reply #2 on: October 18, 2008, 03:19:18 pm »
I think they work equally bad both ways, however you can stand just a tad closer if you mount them horizontally
Shieldwolf
  • SpearShield.com
« Reply #3 on: October 19, 2008, 11:45:11 am »
When I built my cab I did not foresee needing space for light bars. As a result they wasn't enough room for them my bezel and plexi. I ended up putting the bars behind my bezel running vertically on the sides of my monitor. I  then cut small slits in the bezel where the sensors are. I made sure that they were not obstructed. I haven't had a chance to test it out, but it looks really nice and you don't notice the holes in the bezel at all.
aljupy
  • Last login:October 23, 2011, 07:30:06 pm
« Reply #4 on: October 20, 2008, 05:20:07 am »
Horizontal: Will reduce your gameplay distance around half meter.
Under some distances is slighty apreciated. On a 27" inch I would go for Vertical Set up, You should play from 2,5 or 3 meters wich should not be a pain.
Vertical: It is simplest way to hook it. Also is the best way to know that you are inside a "playable" area, because the Bars are ON THE EDGES.
Enjoy your Topgun  :cheers:
