Author Topic: help please  (Read 1485 times)
nightwulfe
  • Last login:June 30, 2014, 04:47:51 am
help please
« on: July 13, 2008, 01:42:54 am »
I have a setup that goes like this
p4 2.40 ghz 512 of ram what is the best software to use to run mame and snes,nes on i will be using a ipac 2 for button configs.
gameex runs to slow this is for a arcade in a box build i am making
« Last Edit: July 13, 2008, 01:46:55 am by nightwulfe »
Goz
  • KOTA
Re: help please
« Reply #1 on: July 13, 2008, 02:47:49 am »
GameEx is likely running like a dog due to the amount of RAM that your system has. Most FE's + overhead + Emulators are going to perform poorly with low system specs and minimal RAM. You'd see significant performance boost by adding another 512MB of RAM.
headkaze
  • Last login:July 05, 2026, 01:56:04 pm
  • 0x2b|~0x2b?
Re: help please
« Reply #2 on: July 13, 2008, 02:51:53 am »
There are some optimizations you can do in the GameEx Setup Wizard that will improve performance considerably too. There were some issues with some video drivers although I think most of them have been sorted out now. For my Radeon 9800 Pro I have to use an older driver to get decent performance. I think the later versions of the Catalyst driver for that model of card screwed up DirectDraw somehow.
