Author Topic: Arcade Monitor Adjustments  (Read 1656 times)
savj14
  • Last login:April 06, 2020, 07:52:46 pm
« on: November 29, 2007, 06:04:02 pm »
What is the best way to adjust the Color and Brightness??
I tried by playing Street Fighter and going into the Color Test........Take a look at the attached File. This is a screen shot from my PC monitor.........But how exactly is this supposed to look.
I guess I am never really satisfied until I know my Monitor is setup to display the best it can. I always seem to be playing around with the Brightness and color.
Is there a guideline as to how I should go about this??? Some software to run that would help me set this up??
SirPeale
  • Green Mountain Man
Re: Arcade Monitor Adjustments
« Reply #1 on: November 29, 2007, 07:55:52 pm »
You should have all colors about equal, without the colors bleeding.
qrz
  • Last login:October 24, 2015, 03:04:15 pm
  • wrangling electrons since 1978
« Reply #2 on: December 03, 2007, 09:08:27 pm »
a good place to start is the g2 ( screen grid) set up
turn bright and contrast to min
adjust screen grid  ( lower shaft on ihvt )  to the point a hint of video appears on screen
then adjust contrast / brightness to desired levels
for chroma balance   " greyscale or white balance "...  as Peale stated  .
note the bottom starcase should run from white to blk,  and it should not be tinted  r, g or b
qrz
