Author Topic: Installing ArcadeVGA Drivers  (Read 1772 times)
DaveJ-UK
  • Last login:January 11, 2025, 04:20:37 am
  • Dirty Dawg
    • ChronicGames.NET
« on: September 11, 2007, 12:03:27 pm »
I have a PC with an ArcadeVGA card hooked up to a WG monitor.
The BIOS screen displays fine, as does the Windows boot screen, but then when it gets into Windows (2000) it just displays a 4 inch black and white band at the top of the screen. I can't get a picture I can work with to install the drivers no matter how much I adjust the pots. Windows safe mode is no better.
So how do I install the drivers?
I tried taking the ArcadeVGA card out but I can't install the drivers unless it's in there.
Any ideas?
bluevolume
  • Last login:July 22, 2019, 12:14:32 pm
  • I wish I'd bought more pins...
Re: Installing ArcadeVGA Drivers
« Reply #1 on: September 11, 2007, 12:37:33 pm »
You should be installing the drivers with a regular PC monitor attached (to the DVI port).  That should solve your problem.
SABRECADE LIVES ON
DaveJ-UK
  • Dirty Dawg
    • ChronicGames.NET
« Reply #2 on: September 11, 2007, 12:50:16 pm »
Thanks but I've got one of the older cards that doesn't have DVI out.
I don't get anything on a regular monitor from either of the 9-pin DSUB's on it.
bluevolume
« Reply #3 on: September 11, 2007, 12:53:38 pm »
Sounds like there is a bigger problem here.  Even with the older card you are supposed to be able to connect a PC monitor to one of the ports.  Is the PC a new build, or did you have a different video card installed previously?  You might have some old drivers mucking things up.
SABRECADE LIVES ON
DaveJ-UK
  • Dirty Dawg
    • ChronicGames.NET
« Reply #4 on: September 11, 2007, 01:26:10 pm »
Yes I had some old NVIDIA drivers installed. Removed them, still the same.
So I put the driver setup file in the Startup folder and did it blind.. sorted!
Thanks for your help.
