Author Topic: Parallel LED Setup...Help?  (Read 1498 times)
shawnzilla
  • Last login:May 05, 2022, 12:01:55 pm
« on: April 28, 2003, 12:35:47 am »
Does anyone have a wiring diagram for wiring multiple (three or more) LEDs in a parallel circuit to the computer power supply?
planetjay
  • Last login:April 22, 2019, 10:50:57 pm
  • Ex-Evil Admin Monkey.
    • planetjay.com
Re:Parallel LED Setup...Help?
« Reply #1 on: April 28, 2003, 12:38:04 am »
One. Two. Twenty. All use the same value resistor. You may want that resistor to be a higher wattage though.
planetjay.com. Still in Chicago. Still no hurricanes!
Carsten Carlos
  • Last login:June 28, 2014, 05:06:25 am
  • Projects: Centipede extended, Asteroids
    • Carlos' Centipede-extended
« Reply #2 on: April 28, 2003, 04:15:37 am »
Got a wiring diagram on my homepage - somewhere under LED. The only real way is to have a resistor for each LED -twenty LED's, twenty resistors.
Explanations why are there, too!
But know I'm going on vacation for a week, no more electronic-support by me!  ;)
