Author Topic: Any cabinet diagrams for 20" CRT?  (Read 2119 times)
hellothere123
  • Last login:March 02, 2021, 03:39:27 am
« on: August 02, 2007, 09:28:35 pm »
I have the plans for a 27" cabinet, but wanted to know if anyone has one for a 20" CRT I'm using. If not, I'll modify the one i have...let me know!
BobA
  • What Me Worry?
Re: Any cabinet diagrams for 20" CRT?
« Reply #1 on: August 03, 2007, 11:05:35 pm »
Should fit into any cab that takes a standard 19 inch monitor.   Most arcade cab plans with that size will probably work.
xmenxmen
  • Last login:September 16, 2012, 03:05:35 pm
« Reply #2 on: August 06, 2007, 01:24:20 pm »
I have a 21in crt monitor inside a ms pacman cabinet.  It fits perfectly fine and can even fit a 25in tv if you can find a slim enough.
Brumaz
  • Last login:July 07, 2009, 08:01:54 am
« Reply #3 on: August 28, 2007, 05:37:51 am »
modifying the plans you have shouldnt be too hard. Matching the cab to the monitor can be an important part of the planning process in that knowing what monitor your using should be one of the first steps in making a cab IMO
a Smith and Wesson beats four aces!
