Author Topic: Most popular frontend and why?  (Read 1690 times)
Xenepp
  • Last login:May 19, 2009, 06:53:48 pm
  • Jeff minter is GOD!!
    • Videotopia.Co.Uk
« on: May 08, 2007, 10:26:53 pm »
It's been a while since I've scoured these forums and since I've just got hold of a nice stand-up cab, a PC and some Ultimarc gubbings the only thing left to investigate is the frontend.
I plan to run XP on my P4 with an ArcadeVGA and Mini-PAC, which frontend might suit best?
More to the point, what is everyone using these days and what layouts/schemes are the favorites?
I remember actually seeing a thread ages ago which dealt with hiding XP at boot time and minimising XP components. This is of particular interest since I only plan to run MAME on the cab, nothing else.
I did try to search but nothing came up (I tried with topics I knew existed though and it didn't find them either  ???)
Anyway, thanks in advance guys!
 -Joel
Buddabing
Re: Most popular frontend and why?
« Reply #1 on: May 09, 2007, 12:19:14 am »
 -Joel
The most popular front end may not be the one that fits your needs.
Please consult the wiki for a front end comparison.
Please read the wiki!
Anubis_au
  • Last login:January 15, 2023, 10:12:32 pm
  • Ever danced with the Devil in the pale moonlight?
« Reply #2 on: May 09, 2007, 03:00:02 am »
I can't comment on front-ends because I've not looked that much into them yet, however I can help with the threads on hiding windows, shelling your FE etc.
http://forum.arcadecontrols.com/index.php?topic=53467.0
http://wiki.arcadecontrols.com/wiki/Hiding_Windows
Good luck with it.
unclet
« Reply #3 on: May 09, 2007, 08:53:42 am »
Based on discussions in the software forum, I would believe (in no particular order) that the following frontends are talked about the most:
AtomicFE
Mala
MameWah
GameEx
This in no way means that other emulators listed on the Wiki would not suit your needs .... I am just trying to save you time.   When I was searching for a frontend I did not really want to have to install tons of different frontends to make a decision ... I just preferred to try the FEs which most people were talking about at the time.  Hope this helps you out a bit.
PS:  The frontends listed above will give you a really good taste of what types of options are currently available for use in a frontend.
« Last Edit: May 09, 2007, 10:37:49 am by unclet »
MustardTent
  • Last login:February 22, 2015, 12:14:02 pm
    • Blog
« Reply #4 on: May 09, 2007, 09:34:59 am »
Agreed.  Take the time to try more than one frontend.  Get to learn how they look/feel on your machine.  Have fun with it -- one of the best parts of making the cab is putting together a really slick user interface.
Chunce DeLeone
  • Last login:August 16, 2012, 02:58:11 pm
« Reply #5 on: May 09, 2007, 09:36:03 am »
MALA with the Gamelauncher layout...................Simple, to the point, easy to set up!!!!
Anubis_au
« Reply #6 on: May 09, 2007, 10:02:20 pm »
When I started researching a new build-from-scratch, one of the things I looked into was windows based FEs, as I previously used DOS based advmenu/advmame.
I looked into Mamewah and Mala, and found I really liked Mala. The interface can be configured to look however you want, and Mala supports some extra functionality that I now want to include in my cab:
1. Program the U360s at game launch, so the joysticks behaves correctly for every game
2. Ledwiz plug-in, so only the buttons used in a game get highlighted.
It is these considerations that make me want to go Mala, but it all depends what you want out of your cab...
