Author Topic: Raster to Vector via Illustrator's CS2 Trace functions  (Read 2830 times)
Trebeck
  • "The Arcade" - Build #4
« on: April 23, 2007, 08:19:51 pm »
Hey all
This is a very specific question.
I've been playing around with Illustrator's Tracing abilities and have been getting nice results but not great results.  Can anyone guide my in this?  What kind of default settings do you prefer?  Can you see anything I should be doing differently? (See pic)
Thanks to anyone who can  guru me here
Beck
www.trebeck.ca
Flip_Willie
  • Last login:November 02, 2020, 11:20:46 pm
    • FlipWillie's Site
Re: Raster to Vector via Illustrator's CS2 Trace functions
« Reply #1 on: April 24, 2007, 12:03:00 am »
   If you are wanting it to be highest quality, then the settings in the attached picture should be what you want.  Be warned, it will take a while to trace with these settings.
   I am no expert, however.  Just play around with the settings till you get something you like, it really depends on what you want it to look like.
   EDIT: Also, checking and setting up "resample" will improve the quality of the picture.
Just as it is,
Flip Willie
« Last Edit: April 24, 2007, 12:10:47 am by Flip_Willie »
zorg
« Reply #2 on: April 24, 2007, 04:38:27 am »
the best settings for autotracing is DON'T USE IT, unless you want to trace some noisy and crappy part.
I'm on the planning stage
Flip_Willie
    • FlipWillie's Site
« Reply #3 on: April 24, 2007, 09:41:18 am »
This is true for the most part.  It's like I said, it depends on what you want. ;•)
Just as it is,
Flip Willie
« Last Edit: April 24, 2007, 09:49:09 am by Flip_Willie »
stephenp1983
  • Last login:March 24, 2024, 11:26:39 am
« Reply #4 on: April 24, 2007, 07:42:53 pm »
I saw a tutorial on the live trace feature, which I wasn't aware of because I'm just a novice user.  I thought it was awesome in theory but when trying it go mediocre results at best.  Its neat, but I never could get anything usable out of it.
zorg
« Reply #5 on: April 25, 2007, 02:22:58 am »
hehe....
live trace may be usable in a really few case, some random noisy patterns, but except for that it's useless.
you will spend more time tweaking, the autotraced path than tracing it by hand.
Trebeck
« Reply #6 on: April 26, 2007, 12:49:59 am »
Crap.
Thanks for the advice guys.  Ah well, gotta do it the old fashioned way.
melarky
  • Last login:July 12, 2020, 12:49:22 pm
  • If I could be any animal, I would be a llama
« Reply #7 on: May 04, 2007, 02:10:39 pm »
I have had better results with auto tracing bitmaps into vector with inkscape (http://inkscape.org/ - it's a free open source graphics editor program).  I use it all the time for my CNC machine, so it's a different application, but it does seem to trace better than illustrator...
zorg
« Reply #8 on: May 05, 2007, 09:10:23 am »
CNC machine, I guess you let inkscape trace some straights lines and some nice curves, not complex patternns and shapes like the ones reqested to trace some artwork.
melarky
« Reply #9 on: May 07, 2007, 02:22:35 pm »
I have a sign carving program that accepts vector images, so if the person that wants the sign has a logo or something they need in it, and they don't have a vector version, 9 times out of 10, inkscape can do a good enough job of tracing it for the sign (some are fairly complex tracings).  I have just found through personal experience that inkscape always does a much better and cleaner job of tracing than illustrator (which is frustrating since illustrator costs so much).
melarky
« Reply #10 on: May 07, 2007, 02:24:23 pm »
Also, just as a quick side note, I only use inkscape for the tracing, I hate everything else about it interface wise (way clunkier than adobe products).  If I could get the same results out of illustrator, I would gladly stick with it for tracing, but I think LiveTrace is garbage...
