Author Topic: Need help removing marquee from cab  (Read 2326 times)
M.Lanza
  • Last login:October 09, 2015, 09:51:03 am
« on: February 26, 2007, 02:51:38 am »
Last year I discovered mame in all of it's godliness while looking for info
about my favorite arcade game "sinistar".
After a few unsucessful attempts at trying to get a sinistar, I downloaded mame
and started playing around with some games. After looking around for some more info
about mame, I came across a page with a tutorial on hacking psx pads into arcade controlls
which also led me to the dicovery of people who had built or converted arcade cabinets
that could be used with mame.
After a couple of weeks of non stop reasearching, I came to the conclusion that I wanted my own
mame cabinet. I don't have the space or woodworking skills to build my own from scratch, so I
decided that converting an existing cabinet would be my best choice.
After looking around at places that I would most likely find arcade machines,
I came across a non working coors light bowling in a generic cab at a pool hall about 20 blocks
from my house. I got in touch with the owner and got the bought the cab for 35.00 and
pulled it home with a dolly.
On the way home though, I hit a pothole, the cab fell over and broke a good sized chunk from the
top left hand corner near the marquee.
I've since converted the cab with a pc and later an xbox but have now setteled on converting
it into a neo geo mvs. I now have most of the hardware needed to do the conversion and
am ready to start reparing the missing chunk of mdf and painting the cabinet.
However, there is one issue that has been nagging me ever since I got the cab.
I can't remove the marquee retainers which makes it impossible to properly repair the cabinet
or to even change the marquee. I've removed two screws holding the bottom retainer in place.
The retainer can wiggle up and down without the screws but I can't get it to come out.
Since the cabinet has no back door like most other cabinets, I've even climbed inside to see
If there might be anything that might be keeping it from being removed and so far I'm stumped,
so I've come here seeking guidence.
this is a picture of the cab I have.
Code: [Select]
http://www.wickedretarded.com/~crapmame/12.html
This isn't mine, but it is the same one  ;)
I haven't found any info on who built this cab other that a sticker on the inside that
says "plateau inc." along with a date of 4-11-90 which I am assuming is when this cab was built.
Ther was a lock on the top of the cab close to the front of the cab that I had drilled out since
I didn't have keys for it. I had assumed that the top somehow opened to allow the removal of
the marquee and to change the florescent tube when it burned out, but I had assumed wrong.
My second guess it that the lock is there just to hold the marquee in place, but I still can't remove
the marquee even though the lock is gone.
So does anyone have any suggestions on how I can remove it?
I've exersized a good amount of force on it, but I don't wan't to cause any mor damage to the cab.
Also, does anyone know anything about this cab?
« Last Edit: February 26, 2007, 03:47:48 am by gimp_hand »
Trample the weak, hurdle the dead
shardian
Re: Need help removing marquee from cab
« Reply #1 on: February 26, 2007, 02:56:39 am »
First, you need actual pictures of your cabinet for us to have a better idea of what is going on. Second, you better address your image link. The hoffster and his puppies have burned my retina's. ;D
M.Lanza
« Reply #2 on: February 26, 2007, 03:05:15 am »
All right.
I can get some closeups of the marquee retainers in a bit.
Address my link?
shardian
« Reply #3 on: February 26, 2007, 03:18:24 am »
Address my link?
Yeah. If that is your cabinet, then you have more serious problems than a marquee. Apparently you can't hotlink from wherever you got the picture from. They have substituted in a "special" picture for you.
Circo
  • Last login:May 11, 2020, 03:27:51 am
  • Still using screenshots? Try EmuMovies instead.
    • EmuMovies
« Reply #4 on: February 26, 2007, 03:23:40 am »
Eyes are burning THE PAIN THE PAIN!!!!!!!!!!!!
 :cry:
I never meant to Hassle the Hoff, why did you make me do it.
« Last Edit: February 26, 2007, 03:25:44 am by Circo »
My Websites
M.Lanza
« Reply #5 on: February 26, 2007, 03:46:24 am »
all right, I fixed it.
I have to charge the batteries in my digital camera, so I won't have any pics of mine
untill later in the day.
FrizzleFried
    • Idaho Garagecade
« Reply #6 on: February 26, 2007, 09:51:08 am »
Am I seeing things correctly?  Did he actually link to CRAPMAME on purpose?
Say it isn't so!
M.Lanza
« Reply #7 on: February 27, 2007, 07:07:14 am »
Say it isn't so!
Yes, I did that on purpose  ;D.
So far it was the only pic that I could find of a cab that looked like mine.
It was even the same color before that person decided to paint it green.
Anyway, even with that persons somewhat limited skills,
he/she had removed the brackets in order to change the marquee,
so I don't understand why i'm having such a hard time with it.
