Author Topic: Database update  (Read 3510 times)
Karaokedude
  • Last login:October 16, 2007, 12:21:00 pm
Database update
« on: February 14, 2007, 09:31:45 pm »
Ive noticed that when you start wincab and the database updates you only get some of the songs actually listed on the title cards.
escaping and restarting gives you another randon selection
is there (or could it be implimented ) a way to update generated list without  restarting
ie from a key
by the way my tri vue project is getting there slowly
using a keywiz eco as the controller remapped with wincab autoloading via a batch file hopefully once its all up and running and ive ironed out all the bugs I will post a full report of everything Ive  done to get it working hopefully 100%
Karaokedude
Re: Database update
« Reply #1 on: February 14, 2007, 09:41:51 pm »
forgot to ask what is the number of songs it actually puts on the title cards
Chris
  • Moderator
    • Chris's MAME Cabinet
Re: Database update
« Reply #2 on: February 15, 2007, 09:12:01 am »
It should put all of them on the title cards.  Check your control map in controls.ini; are you sure you're using Next Page/Prev Page and not Next Alpha/Prev Alpha to go through the list?
--Chris
--Chris
Karaokedude
Re: Database update
« Reply #3 on: February 15, 2007, 09:34:28 am »
yep was set to next and prev alpaha
what is the difference between the 2
although i like the idea getting random lists when i load wincab
Chris
  • Moderator
Re: Database update
« Reply #4 on: February 15, 2007, 09:47:20 am »
NextPage/PrevPage goes to the next page or previous page... NextAlpha/PrevAlpha skips to the next or previous artist in the alphabet.
There's a setting for that, SongSort = TrueRandom, in jukebox.ini.
--Chris
--Chris
