Author Topic: How to copy xbox backups (how to copy xbox copies)  (Read 2990 times)
spystyle
« on: December 24, 2006, 10:51:49 am »
I kept reading that this couldn't be done, then I stumbled upon a post somewhere where a kid said he did it with Alcohol, I tried it and it works on my modded Xbox.
Here's how:
1. insert the xbox backup disk into PC's dvd drive
2. start "120"
3. click image making wizard
4. under "session" - click "01". Then click "next"
5. under "image location" - choose location. Then click "next"
6. locate "file.mdf" and change it to "file.ISO"
7. Burn as normal ISO, I use Nero  @ lowest speed.
Cheers,
Craig
markrvp
  • Last login:April 13, 2026, 04:51:46 pm
  • NFL Expert
Re: How to copy xbox backups (how to copy xbox copies)
« Reply #1 on: December 24, 2006, 03:32:49 pm »
You can also do it with DVD Decryptor.
Put backup XBOX DVD in DVD drive
Open DVD Decryptor
Choose ISO MODE (instead of FILES)
Click Start.
It creates an ISO and MDF (or MDS, I don't remember) file for you.
Use ImgBurn or Nero to burn the ISO to a DVD
It works!
spystyle
« Reply #2 on: December 24, 2006, 06:11:54 pm »
Groovy,
This is good info as DVD decriptor is freeware :)
Cheers,
Craig
SNAAKE
  • Trade Count: (+29)
« Reply #3 on: December 24, 2006, 07:33:34 pm »
use nero express
pointdablame
  • Last login:April 01, 2026, 10:20:52 pm
« Reply #4 on: December 25, 2006, 02:09:07 am »
Copying copies is actually very easy... were you perhaps reading about copying original games??
You can use Nero, Alcohol, CloneCD, DVD Decrypter and I'm sure most others to make copies of already burned games.  It's the originals that would give you some trouble.
first off your and idiot
spystyle
« Reply #5 on: December 25, 2006, 09:36:46 am »
Xbox copies can't be read in window's explorer, try it out, it's not like PS2.
pointdablame
« Reply #6 on: December 25, 2006, 11:48:36 am »
I know that, but that's because the file structure isn't native to Windows.  That doesn't mean you can't make copies of a copy though.  Almost any burning program will be able to make a copy of an already backed up Xbox game because the "hard part" has already been done.
So you can likely use any burning program you'd like :)
spystyle
« Reply #7 on: December 25, 2006, 01:39:54 pm »
Cool
Tnx
If nothing else - this thread will be Googled to counter the threads elsewhere that say you can't copy copies
whatzcrackn
  • Last login:January 19, 2019, 12:14:02 pm
  • U just won tickets to da 'GUN SHOW'
« Reply #8 on: December 25, 2006, 05:17:34 pm »
use nero express
yelp!  turn and burn  :cheers:
