Author Topic: cutting upright sides  (Read 2821 times)
Brumaz
  • Last login:July 07, 2009, 08:01:54 am
« on: October 31, 2006, 08:45:44 pm »
I'm about to cut up the sides for an upright cabinet. Instead of cutting one, then stencilling to make the other, is there anythign wrong with doing this:
clamp both sheets together exactly lined up, making sure measurements are spot on, and cutting both sides at once with a circ saw?
Seems to be an easy way to me (in theory anyways!)
a Smith and Wesson beats four aces!
kingflynn
  • Last login:May 01, 2023, 07:39:02 am
Re: cutting upright sides
« Reply #1 on: October 31, 2006, 09:44:05 pm »
As long as your clamps are tight, and the pieces arent sagging, you'll be fine.  After they're cut, you can keep them clamped and sand the edges at the same time too, to get them both exact.
Brumaz
« Reply #2 on: November 01, 2006, 01:07:11 am »
seems to have worked great. measurements were exact to start, so its saved me a bit of time
mccoy178
  • Trade Count: (+9)
  • Go Bucks!
« Reply #3 on: November 01, 2006, 01:13:21 am »
I did that, the I used a router and guides after the circular saw.  Looked like it came off of a cnc router.
MaMeNnO
  • Last login:August 18, 2021, 10:06:42 am
« Reply #4 on: November 01, 2006, 02:51:41 pm »
I did that too (http://forum.arcadecontrols.com/index.php?topic=57189.msg572469#msg572469)and it works excellent! My opinion, that's the best way to do it when you don't have access to a cnc kinda machine.
« Last Edit: November 01, 2006, 02:55:05 pm by MaMeNnO »
WaRpEd
  • Last login:December 03, 2022, 12:00:41 pm
  • The older I get the better it was!!
    • Warped products
« Reply #5 on: November 04, 2006, 06:53:08 pm »
I always clamp and cut both sides at the same time for accuracy and speed.
why cut both out twice? I have a Porter-Cable hand held sander for sanding the edges and it works FANTASTIC. Wish I'd bought it years ago.
Good Luck with your cabinet.
There are three kinds of people in the world those that can count and those that can't.
