Author Topic: wanted: how to rollback 1.03 romset to 0.53  (Read 1420 times)
Svaroh
  • Last login:May 21, 2007, 01:44:32 pm
« on: July 29, 2006, 05:51:50 pm »
 i chose 0.53 because the cpu i have in my cab is only about 400mhz.
is there a way to 'downgrade' the 1.03 romset to make it compatable with mame 0.53?
i originally had about 30 games on the cab then when i added the rest of the set, none of the additions worked, and some of the original 30 even stopped working. if it at all makes a difference, im using mamewah as a frontend
thx
loadman
  • Last login:June 04, 2026, 06:30:44 pm
  • MaLa FE developer
    • MaLa
Re: wanted: how to rollback 1.03 romset to 0.53
« Reply #1 on: July 29, 2006, 07:17:45 pm »
Svaroh
« Reply #2 on: July 29, 2006, 07:20:22 pm »
are you asking me if i can, or telling me i can? im confused :-\
ill read some more about ctrmame, thanks
loadman
  • MaLa FE developer
    • MaLa
« Reply #3 on: July 29, 2006, 07:26:05 pm »
Sorry I was not clear It was a Question for you to check on.  I've never gone backwards before.
I do understand why you would. I use mame .79 and mame .89
But I say give it a go if you have roms backed up on DVD/CD you can not do any permanent damage
Read up on it I say
