Author Topic: Resolution issue  (Read 1939 times)
jck_strw
  • Last login:July 07, 2009, 11:17:04 pm
Resolution issue
« on: July 01, 2006, 03:47:21 pm »
Hi
I've gone through a couple dozen games and Tempest is the only that's giving me a problem.  It's too large for my TV.  I used to use Mame32 and I had set the resolution to 800x600 there and it wrote it to a config file.  Now, I'm using regular Mame and I'm not sure where I need to set the resolution for specific games.  I looked at .\cfg\tempest.cfg and it looks like I should set it there, but I'm not sure of the syntax.  My default mame.ini has resolution=auto and that seems to work for every game but Tempest.  How can I set this to 800x600?
Thanks.
jck_strw
Re: Resolution issue
« Reply #1 on: July 01, 2006, 04:32:53 pm »
Fixed!  Copy mame.ini to <romname>.ini and set the resolution there.
The .\cfg\ folder seems to be just for controllers.
This was helpful http://www.mameworld.net/easyemu/mameguide/mameconfig.htm
Thanks.
miles2912
« Reply #2 on: July 01, 2006, 05:35:08 pm »
The mame resolution tool is a godsend here...  Highly recommended.
http://mamewah.mameworld.net/downloads.htm
D-
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #3 on: July 01, 2006, 08:23:04 pm »
Thanks.
Small suggestion: if you only want to set the resolution, erase all the other lines in <romname>.cfg.  That way if you make a change in mame.ini, it will also affect <romname>.  (Otherwise you need to make the change in both files.)
Robin
Knowledge is Power
jck_strw
« Reply #4 on: July 02, 2006, 01:46:22 pm »
Good tip, thanks!
