Author Topic: atomic fe help  (Read 1090 times)
crabbymike
  • Last login:August 26, 2006, 06:56:41 pm
atomic fe help
« on: June 20, 2006, 08:35:42 pm »
I have Atomic fe installed and was wondering how to get the english version of the manager program going. When I start the manager program it asks for what language but has no selection in the display. When I open it, it has a couple of things in english, but the rest in french. :banghead:
youki
  • Last login:October 12, 2025, 12:33:39 pm
  • Atomic Front End Creator
    • Atomic Front End
Re: atomic fe help
« Reply #1 on: June 21, 2006, 04:37:41 am »
Hi,
As i said you in the private mail.  That's not normal that the language selection dialog is empty. I suggest you re-install AtomicFE.
In the AtomicFE folder you should see file:
ATOMICMANAGER_ENGLISH.LANG     , that the file that contains english data for the manager.  If you don't have it , or if it is empty ,  re-install Atomic.
If you have it and it is not empty and your language selection dialog is still empty.  explain me how you launcher AtomicManager.exe  (from a shurtcut, being in the folder and double click one the exe...?)
thanks
