Author Topic: help with backlight wiring  (Read 1553 times)
kiddk1
  • Last login:August 01, 2022, 10:58:08 am
  • HAP KI DO
« on: May 24, 2006, 07:34:02 pm »
the light and wires in this cab are original.  The 3 wires came out of a molex that also had the speaker wires.  they go to a transformer and a super starter.  my question is can I make this work with a standard pc power supply and if so how do I wire it?
or would it be easier to some how add different lights?
Its easy to like someone,
If you dont know them very well.
BobA
  • What Me Worry?
Re: help with backlight wiring
« Reply #1 on: May 25, 2006, 11:40:53 am »
The 3 wires for the lamp are probably AC power and ground.   You should look at Bob Roberts site to wire the flourescent fixture.
http://therealbobroberts.net/fixture.html
You cannot hook to a PC supply unless you have an old AT supply with the AC out for the monitor.  Just as easy to put on a 3 wire AC plug.
BobA
Havok
  • Trade Count: (+17)
« Reply #2 on: May 25, 2006, 01:05:59 pm »
Don't bother with the power supply - it takes 120V. Since you have to plug the power supply into 120V anyways, tap off of that and connect to the power strip, or however you have power coming into your cab. I wired up an old lamp cord that I cut the end and stripped the wires to connect on the light side, and had the standard plug to go right into the power strip.
If you get one of the Bits Ltd power strips, it will turn on the light when you turn on the computer...
Malacus
  • Last login:April 17, 2010, 12:42:16 am
  • DANCE!
« Reply #3 on: May 25, 2006, 02:23:11 pm »
http://forum.arcadecontrols.com/index.php?topic=52874.0
I asked this same question.
I just wired a plug from home depot onto the lamp and plugged it into the power supply, works perfectly after replacing the starter.
Mal
~Classic Gaming Since 1983~
kiddk1
  • HAP KI DO
« Reply #4 on: May 25, 2006, 05:02:29 pm »
thank you for all the replies, I did a search on backlight wiring I should have included the word marquee in it.
