Poll
What do you use for a 2-way joystick?
Total Members Voted: 0
Author Topic: 2-way joysticks  (Read 2018 times)
FractalWalk
  • Newbie
  • Last login:September 20, 2010, 06:12:37 pm
  • Life is time spent fighting entropy.
2-way joysticks
« on: March 03, 2003, 07:08:19 pm »
I haven't seen alot of discussion on 2-ways, so I was just interested in what everyone is using. If you choose other, please explain.
saint ganked my avatar.
Lilwolf
  • Last login:June 08, 2026, 09:58:06 am
Re:2-way joysticks
« Reply #1 on: March 04, 2003, 03:36:35 pm »
I still want a defender/joust 2way so that I can setup defender with the reverse button close enough to hit it with my thumb.
but other then that... I don't think it's needed...
brandon
  • Last login:December 26, 2025, 08:29:45 pm
  • I <3 arcade games.
Re:2-way joysticks
« Reply #2 on: March 04, 2003, 06:11:39 pm »
You forgot to add "I use an 8-way for everything because I got skillz" answer to the polls ;D j/k
FractalWalk
  • Newbie
Re:2-way joysticks
« Reply #3 on: March 04, 2003, 06:52:37 pm »
Lilwolf, when you say you don't think its needed, do you mean that you don't play games that require a 2-way or that you you use something else instead of a 2-way.
The reason I am asking is because if I can get away using a dedicated 4-way as a 2-way without it being too sloppy, then my CP design and artwork looks a lot different than if I use an Oscar restrictor to get a good 2-way "feel".
I have read the debates over using an 8-way as a 4-way and how it just isn't acceptable for many people. Do those same people not use a 4/8 way as a 2-way or is the feel good enough?
