Author Topic: light gun on hdtv...  (Read 4656 times)
arcadefever
  • Miami Beach Florida
« on: March 27, 2006, 01:56:38 am »
i just bought a 32" hdtv... ps2 and dreamcast look great  :applaud:
only one bad thing...the light gun doesnt work... :cry:
very sad coz house of the dead look great...
anyway to make it work ???? or light gun are only for regular tv ???
thanks
Frosty
  • Last login:December 30, 2021, 11:11:38 pm
Re: light gun on hdtv...
« Reply #1 on: March 27, 2006, 11:22:52 am »
Dreamcast, PS2, Guncon, etc.---light guns will not work on a high-definition TV.
dabone
  • Last login:July 15, 2025, 08:32:17 pm
  • Time to work...
« Reply #2 on: March 27, 2006, 01:32:58 pm »
arcadefever
« Reply #3 on: March 27, 2006, 08:14:38 pm »
Dave_K.
  • Last login:July 06, 2022, 03:27:30 pm
    • Arcade Fever
« Reply #4 on: March 27, 2006, 09:20:41 pm »
thanks
Depends, did you want to play these lightgun games in progressive mode?  If not, then make sure your HDTV is not internally upscanning the signal, and make sure its not doing something funny like outputing 100hz refresh.  If you can not turn off these options, then you are screwed, and must go the IR sensor route dabone linked to.
If you were wanting to play lightgun games in progressive mode, then you have a couple other options.  If your HDTV supports VGA in, then Dreamcast+DC-VGA box will work like a charm (may need to adjust contrast/brightness to max).  If you don't have VGA input, you could use a RGB->Component transcoder.  Certain PS2 lightgun games will also recognize a progressive display, not sure if the games can actually output progressive video, but if you upscan the 480i component to 480P, it will work).  I've been able to play Time Crisis II and Vampire Night at 640x480@60hz.
arcadefever
« Reply #5 on: March 27, 2006, 10:23:49 pm »
thanks
wowwwwwwwwwwww thanks for that info ...
well my hdtv as vga input  :applaud: i plug the pc with no problem at all .... i will get the dc-vga box ... thank you sooo much .....
Dave_K.
    • Arcade Fever
« Reply #6 on: March 28, 2006, 09:53:39 pm »
Hey bro, hope you don't mind, I'm using http://arcadefever.blogspot.com as my blog. Just realized you own that domain name!   ;D
arcadefever
« Reply #7 on: March 29, 2006, 03:57:50 pm »
that ok  ;D wowwwwwwwww nice pictures (the 2 astro)  :notworthy:
MacroX
  • Last login:October 09, 2007, 11:27:30 pm
« Reply #8 on: March 29, 2006, 08:46:33 pm »
Nice post talk about lightgun work in ps2/xbox/pc with lcd/projector/plasma/crt
http://forum.arcadecontrols.com/index.php?topic=48982.0
arcadefever
« Reply #9 on: March 29, 2006, 09:37:16 pm »
thank you  ;)
