Author Topic: Quick grounding, i pac question.  (Read 993 times)
rlemmon
  • Last login:April 06, 2022, 02:54:46 am
« on: March 11, 2006, 11:02:57 pm »
Hi guys, I get how to daisy chain ( thanks to those who answered my previous post)
I understand that you can run the ground wire back to the ground on your i pac, My question is do you run the wire back to the ground input you started with or do you go to the second input that you haven't used ?
woodygjw
  • Last login:August 26, 2012, 09:33:59 pm
Re: Quick grounding, i pac question.
« Reply #1 on: March 11, 2006, 11:12:26 pm »
It doesn't matter.  The grounds are all connected on the Ipac, they are all electrically the same.  So, it is totally up to you ;D
woody
rlemmon
« Reply #2 on: March 12, 2006, 12:07:13 am »
Thanks woody :)
