Author Topic: Warning the voltage is to low !!!  (Read 2361 times)
Coffein
  • Last login:June 14, 2004, 08:15:41 am
« on: February 12, 2003, 04:14:40 am »
Hi all
My SEGA virtua Fighter cab with the 29" Flat screen monitor
NANAO AMUSEMENTSCAN 29 Type MS9-29SU is startet to come with an error when i power up the cab  ???
There is a nice clear green screeen with this message.
"Warning the voltage is to low ! Please increase the voltage to 5 volt".
Nothing else happens ?
Any idea where i should start here ?
/Coffein
MKL
  • Last login:January 10, 2003, 06:24:51 pm
Re:Warning the voltage is to low !!!
« Reply #1 on: February 12, 2003, 12:58:17 pm »
But what are you powering up exactly? You actually have the game Virtua Fighter (and hence Naomi, or was it Model 2/3?) inside? Check the +5v rail of the game and if it's too low raise the voltage by tweaking the voltage knob on the PSU.
Coffein
« Reply #2 on: February 13, 2003, 11:30:06 am »
It is Sega Virtual fighter II http://home1.stofanet.dk/coffein/virtuaII.jpg
I found the voltage nob and it now seems to work, i screw it 1/4 clockwise and put on a voltmeter, it is now outputting 5.4 volt.
/Coffein
