Author Topic: arcade monitor blues  (Read 2853 times)
deadhead
  • Last login:March 29, 2003, 02:00:06 am
« on: February 10, 2003, 10:04:44 pm »
sorry about the poll first time post
OK I know this is a lame post, but I can
dhansen
  • Last login:November 28, 2025, 10:41:14 am
  • No Quarters Needed
    • Arcade Stupidity
Re:arcade monitor blues
« Reply #1 on: February 11, 2003, 10:34:45 pm »
Do you have the Pclock and Hclock settings for this monitor?  Is it a 15khz monitor? I've been there dude, Advance Mame is a great version but a pain to configure if you don't have the settings for your monitor.
The blue picture seems as if your cable hack is not setup right.  Also, are you combining the vsync and hsync signals from your hack?
I've had the best luck with Trident T64 cards, might be worth the $30 to get one.  I've heard good things about Matrox g400 cards as well but have not had any first hand experience.
Of course you could get the Arcade VGA from Ultimarc and save yourself hours of time and frustration!
Doug
..as his cold lifeless fingers lie motionless on the garage floor, all he could hear in his head was...I JUST WANTED TO PLAY A GAME OF DONKEY KONG!!
deadhead
« Reply #2 on: February 12, 2003, 12:13:42 am »
Thanks for the response Doug. The monitor is 15 kHz and no I don
dhansen
    • Arcade Stupidity
« Reply #3 on: February 12, 2003, 08:42:04 am »
Your rolling problem is probably due to the seperate syncs.  This monitor might have a composite sync. The only monitors I've seen that work better with the seperate snycs is the Eletrohome G07.  Whether you get the Arcade VGA card or not, you'll need to get the sync issue resolved. All the projects I've done (7 and still counting) I've never tied the ground to common, you might want to bypass this for an experiment.
Doug
