Author Topic: Idea for CP wiring  (Read 2014 times)
schwefeljm
  • Last login:February 06, 2003, 02:24:36 pm
Idea for CP wiring
« on: February 06, 2003, 04:37:32 pm »
I am looking at doing this for my CP wiring. These things, I am all but positive use a standard 50 pin Centronics connector (printer type). It qould help make a nice neat set of connection.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=3400404352&category=3309
eightbit
  • My cab is never done...
Re:Idea for CP wiring
« Reply #1 on: February 06, 2003, 05:46:19 pm »
Don't do it, I have to leave right now. I'll be back later tonight to post why.
Luxury
  • Last login:November 18, 2006, 01:21:59 pm
  • Unfortunately It's True. :(
    • arcadeZERO
« Reply #2 on: February 06, 2003, 07:06:35 pm »
ooo.....the suspense!!!   :o
Ph'nglui mglw'nafh Cthulhu R'lyeh wgah'nagl fhtagn.
eightbit
« Reply #3 on: February 06, 2003, 07:35:20 pm »
Sorry about that, I'm back now. I had to take my wife to the local Chinese Buffet for a little grazing with the in-laws.
You don't want to use that wiring block unless you have a straight through cable with a centronics end. If your thinking of using a printer cable don't do it. Printer cables don't use all the pins so they don't contain enough wires. This terminal block looks to me like it would complicate things unecessarily.
I used a much simpler and cheaper 25 pin serial extension cable. I think its also a pretty clean way to go.
Just make sure whatever cable you decide to use is a straight through cable with a wire for every pin. If your doing a joypad hack you might want to use a terminal block to simplify the wiring between the plug and your hack.
schwefeljm
« Reply #4 on: February 06, 2003, 09:29:28 pm »
That is why I had said 'printer type' to describe the connection. The link to the auction was for a 25 pair cable, wired to a centronics connector, for use with a office phone patch panel. (not sure if it is call a patch panel, but that is what it looks like.)
eightbit
« Reply #5 on: February 06, 2003, 10:41:21 pm »
So what are you going to plug into the centronics connection if a printer cable won't work?
$24 for a used punch down block seems steep to me.
