Author Topic: Help, Mamewah & Stretch Using Hardware option  (Read 1217 times)
lettuce
  • Make It So!
« on: January 01, 2006, 02:41:47 pm »
Why when have the, Stretch Using Hardware option untick in the advanced tab of Mame32 for a certain game in this case Alien VS Prediator will mamewah not load the rom?
I have this option unticked because with it ticked i get the old roll over effect at the top and bottom of my monitor.
The screen saying that the rom is loading quickly appears then disappears and the rom doesnt load, i have noticed after this happens in the INI folder for mame32 next to the avsp.ini file (Alien VS Predator) another file appears called avsp.cfg.
« Last Edit: January 01, 2006, 02:43:26 pm by lettuce »
jcrouse
    • CPViewer
Re: Help, Mamewah & Stretch Using Hardware option
« Reply #1 on: January 01, 2006, 02:54:01 pm »
Although some people use it, it is not advised to use Mame32 with MameWAH. THe recommended version is the Windows commandline version of mame.
Just an FYI,
John
lettuce
  • Make It So!
« Reply #2 on: January 01, 2006, 04:34:19 pm »
Can i use the same INI folder that i have with mame32 at the moment with the commandline version? how do i go about changing the res, and other video options with the commandline version?
lettuce
  • Make It So!
« Reply #3 on: January 01, 2006, 04:55:46 pm »
Ok ive pointed mamewah ini file to mame103b DOS version, now when i select a rom to load, a dos window appears soing the rom files loading, then the window dissappears and the rom doesnt load, what do i need to do? is it something to do with the [nodosbox][nosafelaunch] line in the ini file??
lettuce
  • Make It So!
« Reply #4 on: January 01, 2006, 05:32:56 pm »
Ok had a stupid moment, forgot  i need to run mame first to creat an ini file
jcrouse
    • CPViewer
« Reply #5 on: January 01, 2006, 07:34:11 pm »
Don't confuse the Windows commandline version with the DOS version, as you stated. Just because it's commandline doesn't mean it's for DOS. You need the top download from here:
http://www.mame.net/downmain.html
Good Luck,
John
