Author Topic: Help with Dead Eygo Monitor  (Read 2037 times)
Mickey Juice
  • Last login:August 27, 2010, 08:29:08 am
  • BLAU!
« on: December 30, 2005, 02:49:39 am »
I just moved into a new house and after moving my NBA Jam inside I've
got a problem with it.  :(
It initially fired up OK, the only questionable thing was that there
was a wobble in the edges screen, kinda like a degaussing wobble (not that
extreme) and it quitened down and wasn't noticible.
I turned the machine off for a few hours, then when I went to show a
mate I turned it on and nothing  ???
The game board is running fine, the LEDs are on and I can hear the
gameplay sounds. "Showtime!!!!"  ;)
There is no glow from the back of the tube.. I tested the 2 fuses (6A
and 2.5A) on the chassis board and they seem ok (I dont have a continuity
test on my multimeter, so I just used resistence, and the meter was zeroing
ok,  so I assumed there was connection through it).
After leaving it in a repair place for 4 weeks without them even *looking* at it, I got it back from them  >:( >:(
I pulled out the monitor chassis last night and had a look.
The only bad solder joint I could find was on the monitor neck board...
It was the (E) pin that connects to the wire harness around the monitor.
I havnt plugged it all back in yet, but would this be part of the problem?
I've been told that it's probably a switch mode power supply problem or a problem in the deflection circuit, someone else mentioned the B side transistor is prolly dead.
I dont have the equipment to test the transistors whilst in the board.
The brand of both the chassis and tube are Eygo.
« Last Edit: January 02, 2006, 02:48:28 am by Mickey Juice »
censei
  • Last login:November 05, 2009, 11:02:35 pm
Re: Help with Dead Monitor
« Reply #1 on: December 30, 2005, 07:47:52 am »
Since you don't have the tools to test the components, maybe you just want to purchase a new chassis from Alva Amusements, the 25" std res Wei-Ya chassis and forget about the repair? If you want to repair it, you should inspect the chassis for bad/cold solder joints. I believe it's just probably a bad capacitor, most likely the one right next to the big ceramic resistor/vertical ic, but also check the 2 transistors mounted.
« Last Edit: December 30, 2005, 08:06:07 am by censei »
Ken Layton
  • Guru
  • Technician
« Reply #2 on: December 30, 2005, 11:09:23 am »
Looks like it's due for a capkit too.
Mickey Juice
  • BLAU!
« Reply #3 on: January 01, 2006, 06:22:26 pm »
Thanks,
I'll replace all the caps and go from there.
Is it possible to check the trannies with a DMM, while still in the board??
SirPeale
  • Green Mountain Man
« Reply #4 on: January 01, 2006, 07:17:04 pm »
Thanks,
Yes.
Mickey Juice
  • BLAU!
« Reply #5 on: January 02, 2006, 02:01:17 am »
So the method of using the diode test should be ok? ie between Emitter > Base, Base > Collector?
I'm gunna do cap kit, but I still suspect the transistors... but im not 100% up to scratch with testing them. I'll have to do some more reading.
After writing down all the values of all the caps, I tested all the diodes. 1 gave a reading both ways, so i'll replace that and another one broke all together! So i'll replace those two and test.
The broken diode:
The broken diode (top right)
and the non-working one (left)
Mickey Juice
  • BLAU!
Re: Help with Dead Eygo Monitor
« Reply #6 on: January 17, 2006, 09:36:17 pm »
I got this back from a repairer yesterday... There's now power to the board (I can hear the flyback transformer) and some static around the anode plug..
but no glow from the monitor neck  :( at least im getting a bit closer.
