Author Topic: histview problem/question  (Read 1109 times)
ppilot
  • Last login:January 06, 2020, 01:33:27 pm
« on: December 27, 2005, 10:21:49 am »
I'm having a problem using histview.  I've got mamewah set to launch it when I press the left control button.  I'd like to set the alternate escape key in histview.ini to also escape when I press left control.  The alternate escape works if I use a value of 127 (tilda in keycodes.txt) or lower, but anything higher it won't escape (unless I press the actual escape key.)  Keycodes.txt says I should use 307 for the control key.  Anyone know how I can make this work?
