Author Topic: changing the registry to boot into frontend  (Read 1899 times)
neil324
  • Last login:October 07, 2013, 03:53:50 am
« on: October 10, 2005, 06:14:30 pm »
Ive been trying to change the registry in win2000 to boot into atomic fe.
Open regedit and browse to "HKEY_CURRENT_USER\Software\Microsoft\Windows NT\CurrentVersion\Winlogon"
Look for a string entry called 'Shell'. If it is not there, create a string entry and name it 'Shell'. Set the value of this entry to the name and location of your Front-end
ive put the location of my frontend C:\atomicfe\atomic.exe
then when i reboot i get an error atomic.cfg can not be found do you want atomicmanager.exe started instead and i get a blue screen and nothing happens, i can change it back easly by ctrl+alt+del then running redigit again
anyhelp please
youki
  • Last login:October 12, 2025, 12:33:39 pm
  • Atomic Front End Creator
    • Atomic Front End
Re: changing the registry to boot into frontend
« Reply #1 on: October 10, 2005, 06:42:40 pm »
Hi neil324,
Read this topic
http://forum.arcadecontrols.com/index.php?topic=38316.0
you have the solution at the end.
You have to use a .BAT file , to force the default directory.
neil324
« Reply #2 on: October 11, 2005, 12:22:04 pm »
ok thanks think ive got it
As i Said you by mails. To make run Atomic.Fe as Shell.
Create a .BAT file  like that:
Cd \
Cd AtomicFE
Atomic.exe
(adapt it to your folder configuration of course)
Put call it for example : Atomic.bat and copy it in your windows directory.
With REGEDIT edit the registry Key :
HKEY_CURRENT_USER\ SOFTWARE \ Microsoft \ Windows NT \ CurrentVersion \Winlogon
Add or Edit the Key : Shell
And put Shell = Atomic.BAT
Now it should work.
If you are under windows XP , you have to change the way windows open session. to do that :
Control Pane ->User Account->Modify the way the user open session (or something like that, i have a french XP so i don't know what there on US version).  Then Unckeck : Use Startup Screen. (or something like  that).
Then you can eventually use the AutoLogon. Something to change in the registry, you should find information about that in this formum i think.
I did that, and it works for me.
So if my atomicFE is in C then may bat file should be
C \
C AtomicFE
Atomic.exe
and i then place this in C\WINNT folder
and put Shell = Atomic.Bat in the shell value
« Last Edit: October 11, 2005, 12:58:31 pm by neil324 »
youki
    • Atomic Front End
« Reply #3 on: October 11, 2005, 04:02:47 pm »
Yes, it is that part!  ;)
