Author Topic: WinIPAC  (Read 1710 times)
Willypill
  • Last login:October 12, 2005, 11:31:14 pm
WinIPAC
« on: September 25, 2005, 08:14:43 pm »
I set up all my controls in WinIPAC and when I click on 'Program', it starts to program and when it gets to player 3 & 4, my computer makes a beep and it just stops there.  It won't go any futher than player 3 & 4.  I have a 4 player control panel.  What would be the problem?
sc1103
  • Last login:December 11, 2020, 08:37:35 pm
Re: WinIPAC
« Reply #1 on: September 25, 2005, 09:18:36 pm »
Did you configure WinIpac so that it knows you have a IPAC-4 and that the connection is correct (PS/2 vs. USB)?
Willypill
Re: WinIPAC
« Reply #2 on: September 26, 2005, 10:04:39 am »
Yes I did this.
Willypill
Re: WinIPAC
« Reply #3 on: September 26, 2005, 04:12:29 pm »
Why would the IPAC 4 not be responding to players 3 & 4?  I have it wired up exactly the same as players 1 & 2.
On the IPAC 4, only one light is on when I power it up.  It's the player 1 & 2 light.  The other light never comes on.  This is frustrating.
Hoopz
  • Intellivision Rocks!
Re: WinIPAC
« Reply #4 on: September 26, 2005, 04:15:33 pm »
Have you emailed Andy at Ultimarc?  I would do that.  And check out their forums.  Someone may have had the same problem posted there.
Hoopz
Re: WinIPAC
« Reply #5 on: September 26, 2005, 04:46:55 pm »
And you made sure you are connecting the wires to the proper blade on the microswitches?  Make sure that no part of a wire is touching another wire/blade.
Also, double check your grounds from players 3/4.  If you daisey chained them, you should be ok, but it never hurts to double/triple check everything.
