Author Topic: Changing Atomic FE Keys Using Key Manager  (Read 1207 times)
gonzobrian
  • Last login:April 18, 2011, 08:42:08 pm
  • This space for rent!
« on: July 30, 2005, 02:32:45 am »
Was wondering how to use Key Manager in Atomic FE.
youki
  • Last login:October 12, 2025, 12:33:39 pm
  • Atomic Front End Creator
    • Atomic Front End
Re: Changing Atomic FE Keys Using Key Manager
« Reply #1 on: August 01, 2005, 03:05:55 am »
Hi gonzobrian,
This is how works the KeyManager.
-you run it
-you click on start
- then it will prompt  you for each key you can configure.
- at the end of the process (once you have configured all keys) you will be able to save and quit
Text are in French and English.  First row is in Frenche, secon is the same translated.
And , i just see that an Important row is not translated. So the text :
"Appuyer sur la touche qui corresponds
gonzobrian
« Reply #2 on: August 01, 2005, 07:59:58 pm »
Very easy after a little explanation ;D
My mind was just not working on that level this past weekend.
Thanks,
Youki
