Author Topic: Star Wars yoke v STUN Runner yoke  (Read 4193 times)
Wolfman
  • Last login:November 11, 2002, 02:48:22 pm
« on: December 15, 2002, 02:26:17 am »
I've seen photos of both, and noted the difference in the shape of the handles. Are they also different internally? As in, do they rotate and tilt a different amount, use different pots etc?
rampy
  • *shrug*
  • Last login:March 02, 2007, 11:32:16 am
  • ...as useless as a JPG is to Helen Keller
    • Build Your Own PVR
Re:Star Wars yoke v STUN Runner yoke
« Reply #1 on: December 15, 2002, 09:18:26 am »
I think they are the same as far as x/y movement (leftright/updown)
but one thing I did notice or couldn't tell clearly is whether stunn runner had  the "photon torpedo" buttons (thumb "triggers")
But I don't have any reall evidence to back up whether the internal pot specs or gear ratios are exactly the same or not, it's just assumed by most people (i.e. why would atari make it more expensive to produce the same controller for different games and make it look the same...)
*shrug* YMMV
Rampy
PS also - games with funky controllers like this would be more popular with operators if they had conversion games available which also leads me to believe they kept the same exact joystick desgin and just didn;t put x-wing cockpit decals on it =P
« Last Edit: December 15, 2002, 09:19:45 am by rampy »
spidermonkey
  • Bombjack junkie
« Reply #2 on: December 15, 2002, 11:24:26 am »
The S.T.U.N Runner yoke does *not* have any thumb buttons. Only trigger/triggers. Its been a decade since I've played this but I'm 99% sure that I'm right. I don't even think it had two triggers (only one on the right grip) Don't quote me on this because the machine I played may have had its left trigger broken and was missing.
"Sinistar has bad breath"
rampy
  • *shrug*
« Reply #3 on: December 16, 2002, 08:33:32 am »
I'm confused wolfman... is this http://cgi.ebay.com/ws/eBayISAPI.dll?viewitem&item=746328428 you who won this auction, or no?
rampy
botez
  • Last login:September 04, 2023, 11:53:06 pm
« Reply #4 on: December 17, 2002, 04:11:25 pm »
The stun runner yoke has no thumb buttons on it.
Troy
Wolfman
« Reply #5 on: December 17, 2002, 11:14:30 pm »
rampy
Sorry about the confusion Rampy, that was me. When you asked me in email if I was that Wolfman from a message board (forgot the name you used), I didn't think you were reffering to this board, and since I posted only a couple of times, I was pretty sure you couldn't have known me! Sorry about that.
Thanks guys. Do you know of any other mechanical differences aside from the lack of thumb buttons? (already noticed that one). For my gunnery purposes, I need 6 buttons, 3 per handle. That means I will have to drill 2 holes on each handle and fit in 2 pushbuttons. Is there enough space in the handles for this? (I'll be receiving mine soon so I'll know for sure, but still wondering). Thanks!
rampy
  • *shrug*
« Reply #6 on: December 18, 2002, 10:21:59 am »
rampy
If there's not enough space for the buttons, I'll buy it off you (I regret changing course from bidding on the stunn runner yoke to the star wars yoke/cp which then went up to like 138 bucks or more... )
rampy
PS - I thought that was you... I was searching old threads here to confirm that STUN Runner had a simliiar yoke (both x and y axis and not just X axis like roadblasters) and stumbled across your "tank gunnery"/bradlely/battlezone thread... and thought it was more than coincidental that the ebay bidder was wolfman846736  as well as the poster =P
Wolfman
« Reply #7 on: December 19, 2002, 02:39:36 am »
rampy
OK then, I'll let you know how it goes, and if things don't work out, you can have it.
Dav
  • Last login:March 29, 2016, 05:39:35 am
« Reply #8 on: December 24, 2002, 08:40:43 pm »
Stunrunner doesn't center on the y axis.  It's at the lowest point at rest.
Dave
Wolfman
« Reply #9 on: December 25, 2002, 04:25:58 am »
When its at rest, is it tilted all the way forward or all the way back?
Dav
« Reply #10 on: December 25, 2002, 01:12:38 pm »
IIrc it's pretty much centered and only goes down, since the gun only goes up.  I'll check that when I get home.
Dave
