Author Topic: arcade Jamma/CPS 2&3  (Read 1115 times)
alundra
  • Last login:February 02, 2009, 09:30:05 pm
« on: June 11, 2005, 01:52:11 pm »
so if i want to play CPS 2&3 board..all i need is a jamma kick harness? is that all?
i want to turn my cab into a universal arcade..Jamma/MVS/CPS 2&3.. ;D thanks
« Last Edit: June 11, 2005, 01:54:03 pm by alundra »
pointdablame
  • Last login:April 01, 2026, 10:20:52 pm
Re: arcade Jamma/CPS 2&3
« Reply #1 on: June 12, 2005, 12:34:17 pm »
You'll need a kick harness for anything beyond the normal JAMMA button inputs... ie the 4th through 6th button for fighters.
That isn't "all" you need though.. you'll obviously need an MVS motherboard, and a CPS2/3 A/B board combination to play the games.
If you want an all in one machine, you'll probably want a multi-JAMMA board as well so that you can have them all hooked up at once.
first off your and idiot
