Author Topic: Daphne with Cliff hanger and Dragons Lair 2  (Read 1957 times)
dntaskwho
  • Last login:August 04, 2009, 08:02:03 pm
« on: May 03, 2005, 01:44:20 pm »
Hey guys I got a problem. When using the cvs build of daphne. I'm able to run dragons lair ii but cliff hanger is no longer working. Has anyone else had this problem? It hangs up at the death scenes. If I switch back to the official release it works fine.
ddockery
  • Last login:October 29, 2005, 11:51:14 am
Re: Daphne with Cliff hanger and Dragons Lair 2
« Reply #1 on: May 03, 2005, 04:35:46 pm »
The changes in the CVS build broke clifhanger.  The simple answer is to run 2 versions of Daphne.
Marky_1979
  • Last login:January 03, 2017, 11:07:07 am
    • Personal Webspace
« Reply #2 on: May 04, 2005, 04:26:43 am »
2 Versions of Daphne ?? thought there was only one and i was having problems getting that working where can i get this other version.
walls83
  • beer is good
« Reply #3 on: May 04, 2005, 09:28:04 am »
the CVS build runs Dragons Lair 2.  If your not running DL2 the normal "offical" build is all you need.
