Author Topic: need xp help  (Read 1666 times)
dirt
  • Last login:October 30, 2024, 08:36:38 pm
need xp help
« on: May 01, 2005, 01:49:59 am »
i have my machine running windows xp home and every time i turn it on it does not recognize my ipac4,spinner, and trackball, the spinner and tb are oscars mouse hacks. all three of these are usb. if i take them out and put them back in the computer will recognize them and everything is ok until i turn it off and try to start it again. anyone have any experience with this problem?
dirt
WANTED: NINTENDO CABINETS WORKING OR NOT
screaming
  • Sweet! I'mma go make me some popovers!
  • Last login:August 14, 2019, 03:15:34 pm
  • Registered lUser
    • shift eight (*) generation
Re: need xp help
« Reply #1 on: May 01, 2005, 09:48:39 am »
I have, but only when they were attached through a cheap USB hub.  Upgrading the hub fixed it!
Are they connected directly to the computer or connected through a hub?
-sab
dirt
Re: need xp help
« Reply #2 on: May 01, 2005, 02:09:05 pm »
they are connected directly to the computer. also, just to be a little clearer, if i restart the computer the spinner and tb will still work. it is only when i turn off all the power to the cabinet/pc and turn it back on that does not recognize anything plugged into the usb ports.
dirt
AceTKK
  • Last login:August 20, 2011, 01:14:48 am
Re: need xp help
« Reply #3 on: May 01, 2005, 03:51:47 pm »
Do you know what chipset your motherboard uses?  There might be an updated USB driver available.
-Ace-
I want my own arcade controls!
dirt
Re: need xp help
« Reply #4 on: May 01, 2005, 04:27:38 pm »
i know it is a amd athlon 1800+. i dont know what motherboard it is. i bought this pc 2 years ago at best buy. i just replaced the hd with a bigger 80 gig one. i never had this machine in a cabinet until now so this is the first time i have left usb devises plugged into it.
dirt
