Author Topic: Optipac Jumper, which connector?  (Read 2401 times)
coasternuts
  • Last login:January 11, 2010, 08:39:24 pm
  • Ouuuuch....I am not the worst game ever!!
« on: March 05, 2005, 02:38:46 pm »
I want to wire up my Optipac so that it can switch between Rotary and Trackball with a switch( ie. not with the jumper) and I can't find what kind of connector will fit on it.  I looked at some HDD power cables but they looked too big to fit over the wires.
Specifically they are the 6 pins, 3 on top, 3 on bottom, that I'm trying to connect to.
And I don't want to solder to them.
Thanks.
ShinAce
  • Last login:January 16, 2007, 07:38:14 pm
  • Building the unbuildable since 2001
Re: Optipac Jumper, which connector?
« Reply #1 on: March 05, 2005, 09:52:39 pm »
I think it's time you learn to wire wrap.
An ounce of image is worth a pound of performance.
cholin
  • Last login:July 16, 2009, 09:22:25 pm
    • Nilok Productions
« Reply #2 on: March 06, 2005, 12:05:05 am »
Look around on some component sites for a 6 pin molex or something.  Look for polaraized headers or whatever you can get.
Fat_Trucker
  • Last login:September 08, 2010, 11:44:22 am
« Reply #3 on: March 06, 2005, 03:13:34 pm »
If you are talking about connecting to jumper pins, could you not use the little connectors that you use to wire things like front sound ports to your mobo?.
I didn't touch it....honest!
coasternuts
« Reply #4 on: March 06, 2005, 06:53:48 pm »
I was looking at some CD drive connectors that connect to the mobo, but I didn't think about the sound ones.  I'll check this week.  Thanks.
As far as wire wrap'n,  any links to tutorials, just in case?
oldsage
  • Last login:December 19, 2005, 09:11:47 pm
  • Does SHMIGRUB ring any bells??
« Reply #5 on: March 06, 2005, 07:52:09 pm »
« Last Edit: March 06, 2005, 09:22:16 pm by oldsage »
I had a cool sig once... But it had to go because of *someone*... You know who you are!
ShinAce
« Reply #6 on: March 06, 2005, 08:57:06 pm »
oldsage
« Reply #7 on: March 06, 2005, 09:24:21 pm »
Just freakin google it... like so:
http://www.ece.queensu.ca/hpages/sstaff/techserv/wirewrap.html
Sorry man... From some reason it seemed logical that you meant wrapping the wire... My bad, won't happen again (i hope)...
