Author Topic: How to disable Nag Screen  (Read 1645 times)
vader
  • Last login:January 19, 2025, 08:25:22 pm
  • I can't breathe in this thing !!
« on: November 14, 2004, 03:56:42 am »
Mame 88 command line version with MinWah, what file do I have to edit and what are the correct switches to disable the dumb nag screen.......copyright and OK stuff....thanks
tim
lucindrea
  • Last login:July 28, 2005, 10:06:19 am
  • I dont think I'm a llama!
Re:How to disable Nag Screen
« Reply #1 on: November 14, 2004, 04:20:03 am »
heh ya  , you would think after the first 30 or so games you would get the idea  :-X  , i think their is a way to put it in the ini but i dont know it off hand
vader
« Reply #2 on: November 14, 2004, 04:54:21 am »
Well....I figured it out.  First problem was I was using Mame32 which you just check it off and boom was gone.  Well I went the mame command version with minwah and grrrr, no option.  I don't have a INI file.....boohoo....well...a couple readme's later.....had to make one....mame -cc.....tadaa....then just changed the skip disclaimer and ok thingy to 1 and voila.....life is good....btw....MinWha just totally rocks....woohooo...
Tim
DaemonCollector
  • Last login:December 26, 2009, 07:02:16 pm
  • All your base are belong to us.
« Reply #3 on: November 14, 2004, 12:25:03 pm »
You can also get rid of the bad dump windows and all other warnings :) But you have to edit the code to do those.
