Author Topic: Old "arcade" games  (Read 2848 times)
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
Old "arcade" games
« on: September 19, 2002, 01:54:07 am »
Hey, I need to ask the older crowd here a question.  Thinking about it this may not be the right section, but I need as much exposure as possible to find the answer.
Ok, when I wasa SMALL kid I went to the bars alot with my dad.  He was on a pool league.
It was a nickel skill game.  The play field was several ramps and launchers.
You dropped a nickel in from the top.  and it sat on the top ramp.  you controlled a spring powered launcher to roll the nickel to a slot in the ramp to drop ot the next ramp.  How ever, there where holes in the backboard the nickel could fall through.  So it was a skill game.  You had to put just enough spring in the launcher to get the nickel to the slot, otherwise sometimes too much there was a hole in the backboard, too soft there might have been a hole in the backboard.  I got harder as you went down.
I only once made it all the way.  Since it was so cheap, my dad gave me alot of nickels to play:)
Anyone play it?  have any idea what it is?  Any idea where I could find it?
« Last Edit: September 27, 2002, 12:59:47 am by SirPoonga »
kgriffin
  • Last login:August 31, 2002, 02:11:24 pm
  • I look nothing like Brad Pitt!
Re:Old "arcade" games
« Reply #1 on: September 19, 2002, 12:40:34 pm »
Try digging through this site...you might find one (I saw something similar to what you described only with a penny instead of a nickel
http://www.gameroomantiques.com/
SirPoonga
  • Puck'em Up
« Reply #2 on: September 26, 2002, 05:46:44 am »
I FOUND IT I FOUND IT!!!!!!!
http://mamefans.metropoliglobal.com/museum.php?dir=/Antique/BallySkillRoll
(Clickable Link fixed by moderator)
Ok, so my memory wasn't 100% accurate, I PLAYED IT WHEN I WAS LIKE 6!!!!  almost 20 years ago.
« Last Edit: September 26, 2002, 07:36:33 am by JustMichael »
Sasquatch!
  • Toot-Toot!
    • Arcade Paradise
« Reply #3 on: September 27, 2002, 12:00:53 am »
Hey, I need to ask the older crown here a question.
Don't make me bust out the "when I was your age" stories.  >:(
