Author Topic: mamewah porblems (different from other threads)  (Read 1686 times)
Nefesis
  • Last login:August 25, 2007, 11:28:22 am
  • psst... star wars... it's the greatest!!!
« on: October 14, 2004, 09:51:02 pm »
hi. i'm trying to run mamewah w/ mame ver. 55. i have a win 98 computer. the games show up and all, but i can't get any game to load. i can't get the games to load using the command prompt either. however, i can run the games using mame32 and using the exact same roms. is the any explination for this?
Wizard of DelRay
Re:mamewah porblems (different from other threads)
« Reply #1 on: October 14, 2004, 10:09:40 pm »
I have a couple of questions:
1.  Which ROM set do you have?
2.  Which version of MAME32 are you running?
Nefesis
« Reply #2 on: October 15, 2004, 08:42:48 am »
i have mame32 version 84.2. i think the rom set is ver. 87, but not sure.
« Last Edit: October 15, 2004, 01:53:40 pm by Nefesis »
DaemonCollector
  • Last login:December 26, 2009, 07:02:16 pm
  • All your base are belong to us.
« Reply #3 on: October 15, 2004, 08:51:25 am »
The sets have changed drasticly since than, use ClrMAMEPro to fix your roms for .55. That should make them runnable.
Nefesis
« Reply #4 on: October 15, 2004, 08:57:17 am »
ok thanks
Wizard of DelRay
« Reply #5 on: October 15, 2004, 12:33:14 pm »
I figured as much.  It seemed pretty simple from the info you posted.
By the way, you might want to get rid of your link on where you got the roms.
Crazy Cooter
  • Last login:May 29, 2026, 10:28:26 am
« Reply #6 on: October 15, 2004, 06:40:23 pm »
Wouldn't it be easier to use the mame version appropriate for the rom set rather than redo the roms?
Wizard of DelRay
« Reply #7 on: October 15, 2004, 06:47:45 pm »
Yeah, but some people like to switch to the newest version when it's released.  Some also like to stick with a certain older one because others have said that it's the best version with older hardware.
I updated to .87 and found nothing of significant gain so I've decided to stick with .79.  It's the best version before the xml stuff.
liquid8
  • Last login:January 08, 2026, 02:01:16 pm
  • I working on it.. it'll be a while.
« Reply #8 on: October 15, 2004, 10:49:25 pm »
If using the command line version, make sure you are adding the -rp option for the rom path.
LiQuiD8
