Author Topic: Anybody try s-video to rca  (Read 1292 times)
boesiii
  • Last login:November 22, 2015, 07:56:14 am
« on: September 13, 2004, 12:55:48 pm »
I have an old tv that only has video composite support.  What if I use a s-video to rca converter to hook the tv up. What will the quality be?
MonitorGuru
Re:Anybody try s-video to rca
« Reply #1 on: September 13, 2004, 03:39:27 pm »
S video consists of a separate wire for the luminance (Y) [black + white image] and the chromanance (C) [color portion].  A converter would re-multi-plex them into a narrower bandwidth, and depending on the quality of the device, add additional interference/etc..  But in essense, you'll end up with a pretty poor video signal.
A TV works in this order when processing a video signal:
Antenna or Cable:   RF Input -> Composite + Audio separation -> Luminance+Chromanance video separation -> Color Component separation -> Tube
Composite video inputs:  Start in above chart right after Composite separation
S Video inputs: Start after Luminance separation.
Therefore if you're starting with an SVideo signal, convert it to composite and feed it to the TV, you are now going through 2 additional levels of conversion over plugging in Svideo directly if you could:
SVideo -> Composite -> TV -> Svideo -> Component
Which basically means you can probably expect a lower quality signal than feeding Composite directly, and definitely than being able to feed svideo directly.  No matter what you won't have a picture better than Composite outright, since that's the lowest common denominator.
Refer to this thread for comparisons of Composite vs S Video vs Arcade CGA:
http://www.arcadecontrols.org/yabbse/index.php?board=4;action=display;threadid=23818
BarontheFirst
  • Last login:April 11, 2023, 07:42:07 pm
  • Locked out of the gameroom again!
« Reply #2 on: September 16, 2004, 10:29:11 pm »
Yes I wasted the money and was very unhappy with the results! It was almost blinding how bad the picture on my tv was. Trust me don't go that way!
