Author Topic: Xbox-how to change resolution for vga?  (Read 2670 times)
Demon-Seed
    • DemonCade (WORKING URL!)
« on: August 06, 2004, 08:09:10 pm »
Hey
I have evox I think its called installed has mod chip in mit too.. (in the xbox)
I bought a vga adapter called the VCA transcoder thing.. lets you play xbox on a regular pc monitor at HDTV compariable ..blah blah.. anyways.. says to get it to work you need to change your resolution setting in your dashboard???? ie) 480 etc??? anyone advise how I do it????? whats it under?
derek1800
  • Last login:January 29, 2005, 03:23:31 pm
Re:Xbox-how to change resolution for vga?
« Reply #1 on: August 06, 2004, 10:30:16 pm »
did you check in evox settings?
Demon-Seed
« Reply #2 on: August 06, 2004, 10:36:04 pm »
hey
i will double check where abouts should it be?
Demon-Seed
« Reply #3 on: August 07, 2004, 10:53:54 am »
Hmmm I checked cant find it anywhere .. my dashboard is um....evolution x if that helps. the isntrstuctions tell you how to set it in the default xbox.. but I have no idea for this one.
dabone
  • Last login:July 15, 2025, 08:32:17 pm
  • Time to work...
« Reply #4 on: August 13, 2004, 10:32:40 am »
You need to run the msdash. It usually has a menu entry somewhere in the evox menu..
If not use a program like xbox explorer to run the xboxdash.xbe or msxboxdash.xbe file in c:\
(Xboxes are very customizeable as for the software load so the file name might be changed to something else, but these are the 2 most common ones.)
Also look over at the xbox-scene forums, they have tons of help for you.
Later,
dabone
Demon-Seed
« Reply #5 on: August 13, 2004, 10:41:45 am »
Hey
thanks all i did was turn of mod chip and set it in ms dashboard works great
thx
