Author Topic: Wiring a keyboard hack?  (Read 1374 times)
RecycledPast
  • Last login:October 09, 2011, 09:14:47 pm
    • My 2 scratch built arcade machines
« on: June 10, 2004, 04:02:19 pm »
For my first project I used an IPAC but I'd like to replace it with something cheaper since the control panel is only 1 player with a total of 5 buttons (p1 start , p2 start , coin,  p1b1, p1b2)
I've torn apart the keyboard, mapped the matrix, and soldered an IDE cable to it.  I assume I won't have to worry about ghosting since it's such a simple cp.
I'm wondering how to actually wire it up to the buttons.  For example, how do I connect up the player one start button which is the key 1.
Do I connect the two wires that make up the key 1! to NO on the push button? But what about a ground?  Or do I connect one of the wires to the NO and the other to the common  contact?
« Last Edit: June 10, 2004, 04:05:15 pm by Recycled-Past »
JustMichael
  • Mmmmm!! Cheesecake!!
Re:Wiring a keyboard hack
« Reply #1 on: June 10, 2004, 04:08:50 pm »
Since you have mapped the matrix you are almost done.  Connect one of the pins that makes "p1 start" to the NO tab of a microswitch.  Now connect the other pin that makes "p1 start" to the COM tab on the microswitch.  Do this for each button.
