Author Topic: Reverse Button for Defender/Stargate?  (Read 2019 times)
Witchboard
« on: May 18, 2004, 02:46:54 pm »
How do you guys that have made these types of CPs mount them?  From what I can tell, you would end up running into your joystick base.  Do you just put it as close as you can or is there a trick that your using?
I'm trying to figure out how to mount next to a T-Stick Plus.
NoOne=NBA=
Re:Reverse Button for Defender/Stargate?
« Reply #1 on: May 18, 2004, 06:59:50 pm »
The base on the T-stik is small enough that you should be OK just putting the button as close as you can get it.
I built my own using a 8-way Wico clone, and just cut off one corner of the base with a Dremel tool to allow the button to get closer to the stick.
My reverse button is actually a little closer to the stick than the factory ones were, which feels better to me.
REBIRTH
  • Last login:December 28, 2023, 09:10:29 pm
  • What is that?
    • REBIRTH "Rotating Arcade"
« Reply #2 on: May 18, 2004, 07:07:21 pm »
Can't speak for a T-Stick but I made my defender panel using a Happs Ultimate and had no problem.  The base wasn't so big that it got in the way.
:) Rotate or die! :)
Witchboard
« Reply #3 on: May 18, 2004, 07:50:51 pm »
Hmm.. maybe my measurements are off.  The only way I could see how close the button is supposed to be to the joy was to check the distances on the CPO.
spystyle
« Reply #4 on: May 18, 2004, 10:26:21 pm »
The Defender and Stargate CPs had 2way joysticks which are slim allowing the button to be fitted so close, I bought a 2 way joystick off Ebay for my Stargate CP but it is only compatible with 7 games. If you want to make a CP  for Defender that is compatible with a multitude of games I suggest using the Multi Williams.
It plays Defender (and all the other Williams games) with 8 way joysticks increasing the compatibility of the CP with many of MAME's games
and it's a lovely overlay for williams fans
it can be found here :
http://localarcade.com/4images/details.php?image_id=231&mode=search
cutting template = no measuring
Can you dig it ?
Craig
« Last Edit: December 09, 2006, 11:51:36 am by spystyle »
Witchboard
« Reply #5 on: May 18, 2004, 10:46:52 pm »
Yup, I've seen that.  I'm going to have some other controls on the CP so I won't be able to use that CPO.  I'm going to custom make one when I get around to it.  From what I see on that one though, they just put it as close as they can.  Thanks everybody for the help.
DrewKaree
  • HAH! Nice one!
    • A lifelong project
Witchboard
« Reply #7 on: May 19, 2004, 08:25:55 am »
Thanks for the link Drew.  Really won't help me though since I'm going to be using a T-Stick Plus and I'm still wanting to use it 4/8 way.  I'm not sure I feel comfortable cutting on a $25 joystick.  If it was a Happs Comp or something I'd try it in a heartbeat.  I think the best thing is just to get it as close as possible.
