Author Topic: Help! My Mamewah is screwed up!  (Read 1165 times)
dema
  • Last login:September 02, 2014, 03:05:34 am
« on: May 17, 2004, 12:34:00 am »
Can someone help me out with this? My Mamewah is locked into a run-time error 13, Type mismatch screen.
I was trying to get my PC games to run from Mamewah, albeit unsuccessfully. After getting it to work by adjusting several settings within Mamewah I decided to rename my shortcuts so they didn't have a .LNK attached to the end of it. However when I changed that everything started getting screwed up, because the settings I selected in Mamewah weren't saved in the Configuration file. When I rebooted the folder I got the error message, which allows me to hit enter to press the OK option. When that happens it kicks me back into XP in a smaller resolution. Every time I boot up into Mamewah now I'm unable to do anything because the error message locks me out of everything. How do I fix this?
« Last Edit: May 17, 2004, 01:32:31 am by dema »
dema
Re:Help! My Mamewah is screwed up!
« Reply #1 on: May 17, 2004, 01:33:54 am »
Never mind. I removed all of the emulator files that were devoted to the PC games and installed a new one and that cleared the error 13 up without having to do everything all over again.
