Author Topic: PNG effect only applied in horizontal games  (Read 1231 times)
ID4
  • Last login:January 29, 2025, 02:55:51 pm
    • ID4 Retrodev
« on: January 29, 2025, 02:42:34 pm »
The problem is the following:
In my "mame.ini" configuration I have applied a PNG effect for all games, using the "effect" configuration parameter.
The png is applied in all games except vertical ones, when I run a vertical game this effect disappears.
In "mame.ini" I have the "rotate" parameter activated, to rotate the vertical games and play them in my horizontal monitor.
Curiously if I run a vertical game and from the mame menu the I rotate the game again (as if the game was horizontal) the png suddenly appears and is applied to the image.
This happens with version 273 of Groovymame, if I run official mame in the same folder with the same mame.ini, the PNG effect does not disappear when running a vertical game.
What could this be due to?  :banghead:
Thanks in advance
