Author Topic: Wheel2XInput, designed for mapping wheel and wheel accessories to XInput  (Read 138699 times)
nugarp
  • Last login:May 10, 2026, 05:48:47 pm
Re: Wheel2XInput, designed for mapping wheel and wheel accessories to XInput
« Reply #40 on: October 23, 2025, 11:11:30 pm »
Hello, I understand you can use multiple inputs and assign them in Wheel2XInput. I see an example for overriding one GUID with another for say a specific button but here's what I'm trying to accomplish...
I have a TMX racing wheel and the TH8S shifter. I want to map the shifter to currently mapped dpad and paddles on the wheel in the json, not override it, but have both inputs working. How would I code that into the json? I have used the trace app to pull the GUID and button numbers, so just need to know how to inject that info into the json.
Map multiple inputs to the same output, it will work as you want by default as I assume these are digital inputs and not analog that you are making as your targets.
Another way to say this: you can have the same targetButtons or targetDpads for multiple defined inputs.
Eckers569
  • Last login:February 16, 2026, 12:41:42 pm
« Reply #41 on: November 09, 2025, 09:24:49 pm »
I think the code for mapping multiple GUIDs to a single button in the earlier reply might be wrong. I couldn't get it to work.
I tried a mixture of that and Copilot and came up with the following which did the trick for me.
Same Gear shifter as yours,  but my wheel is the TS-PC Racer. Pasted the full json so you can see it in context, but at the end of the 'buttons' section I've mapped A,B,X,Y to 0,1,2,3 on my shifter (gear changes in Daytona!). The plus side is the same buttons still work on my wheel.
Program is especially useful for emulating systems like Dreamcast, where the controller has limited buttons so you need to multitask. Crazy Taxi for example uses A and B to navigate menus but are then gear shifts in game - so I wanted wheel shifting to function while also retaining the face buttons for navigation:
  "guid": "00000003-044f-0000-89b6-000000000000.1",
  "enableForceFeedback": 1,
  "enableRumble": 0,
  "centeringForce": 50,
  "largeRumbleMagnitude": 80,
  "largeRumblePeriod": 120,
  "smallRumbleMagnitude": 50,
  "smallRumblePeriod": 60,
  "effectDuration": 1000,
  "effectAntiDeadzone": 0,
  "detectControllerReconnects": 1,
  "pollInterval": 16,
  "buttons": [
      "button": 0,
      "targetButtons": [ { "button": "A" } ]
      "button": 1,
      "targetButtons": [ { "button": "B" } ]
      "button": 2,
      "targetButtons": [ { "button": "Y" } ]
      "button": 3,
      "button": 4,
      "targetButtons": [ { "button": "Back" } ]
      "button": 5,
      "button": 8,
      "targetButtons": [ { "button": "Start" } ]
      "button": 9,
      "targetButtons": [ { "button": "X" } ]
      "button": 0,
      "guid": "00000003-044f-0000-60b6-000000000000.1",
      "targetButtons": [
        { "button": "X" }
      "button": 1,
      "targetButtons": [
        { "button": "A" }
      "button": 2,
      "targetButtons": [
        { "button": "Y" }
      "button": 3,
      "targetButtons": [
        { "button": "B" }
  "dpads": [
      "dpad": "up",
      "targetDpads": [ { "dpad": "Up" } ]
      "dpad": "right",
      "targetDpads": [ { "dpad": "Right" } ]
      "dpad": "down",
      "targetDpads": [ { "dpad": "Down" } ]
      "dpad": "left",
      "targetDpads": [ { "dpad": "Left" } ]
  "axes": [
      "axis": 0,
      "config": {
        "inverted": 0
      "targetAxes": [ { "axis": "LeftThumbX", "deadzone": 0, "antiDeadzone": 0, "linearity": -30, "low": -110, "high": 110 } ]
      "axis": 2,
      "config": {
        "inverted": 1
      "targetSliders": [ { "slider": "RightTrigger" } ]
      "axis": 1,
      "config": {
        "inverted": 1
      "targetSliders": [ { "slider": "LeftTrigger" } ]
Great little program by the way Nugarp. Once I've got my head around it looks like it can replace x360ce in a lot of similar user cases.
« Last Edit: November 10, 2025, 12:03:09 pm by Eckers569 »
nugarp
« Reply #42 on: November 09, 2025, 11:22:06 pm »
Cheers. The way you have done it is correct, as you noticed :).
I have a 1.6 beta that will send ffb or rumble to multiple devices, so if anyone needs that, find me on discord. It should also support hotswapping of the config.
Eckers569
« Reply #43 on: November 11, 2025, 05:28:46 pm »
Nice one, thank you. I will check out the discord ASAP.
« Last Edit: November 11, 2025, 05:38:47 pm by Eckers569 »
ark216
  • Last login:December 09, 2025, 07:01:15 am
« Reply #44 on: December 09, 2025, 06:58:37 am »
How does this software differ from x360ce. I would really like to test this out with my G29 but since it does not have GUI and is just code based it looks a bit intimidating. Are there any easy user friendly guides where i can follow? I did check it's README, i found it to be a bit confusing.
Eckers569
« Reply #45 on: February 16, 2026, 12:40:36 pm »
There’s a lot of cross-over between this and x360ce to be fair. However, for me at least, I got fed up of x360 constantly deleting settings and never really getting to grips with the per game configs. Never had any such problems with W2X.
Another key benefit is not only being able to map multiple devices to single xinput bindings (which you can also do with x360) but then with any of those individual devices also being able to map multiple buttons from them to a single xinput outputs- which you can’t do in x360 (it will clear a binding if you try to map elsewhere on the same device - see my crazy taxi example above). There’s also I believe benefits of being able send FFB to multiple devices which I’ve yet to explore.
nugarp
Just wait a little bit. I have been pushing hard on an update that was worth the wait. I've been fortunate to have a team of beta testers in the discord that have been helping iron it out. I will update this thread when it is ready. Guess the software didn't die in 2022 after all!
Thanks for responding. You are correct, you can do one-to-many and many-to-one mappings. There will be a lot of fine-grained control that I think will be more relevant for anyone with an FFB device than a generic x360ce implementation.
« Last Edit: March 11, 2026, 09:35:39 pm by nugarp »
eljulo
  • Last login:May 10, 2026, 01:33:08 pm
Hi ! Thanks for your hard work on this one !
I actually work on your wheel2xinput for Outrun2006Tweaks by Emoose to try to improve the ffb effects.. I explain : this works amazingly well. But in Outrun FXT by Howard Casto, i figured how to optimize the spring effects on the game i i'll love refind this feeling with your stuff.
This is what i do : I try to set up the spring effect you add while the car drifting : in fact, when the car begins to drift we have the vibrations but the spring effect disappears and i will love have the spring effect while drifting (like in the arcade). Well, i spend maybe 5 days to try differents settings with the IL  but with no success  :banghead:. Do you think you can take a look on your program pls ?
Best Regards
Julo.
robertdeniro22
  • Last login:April 26, 2026, 04:10:48 am
Hello everyone, I hope this is still active. Does anyone know how to configure the D-pad on DualSense? All the buttons work perfectly except the D-pad directions.
nugarp
Best Regards
Julo.
This is fixed and adjustable in 1.6, which is in beta.
You should use the --trace command and it will tell you what the input mapping for the dpad is. What does --trace look like when you push the dpad buttons? Usually, dpad is listed as dpad instead of axis or button.
