Author Topic: Triple screen crt display with Groovymame install  (Read 3556 times)
Moksi
  • Last login:March 17, 2025, 08:13:58 am
« on: October 23, 2021, 05:50:57 am »
Hello ,
This is my first time installing this software , i aqquired an Beovision MX4000 CRT for use with Mame (mostly Arcade games)
my system is Win 7 64Bit , GPU Radeon R9 380.
I followed this guys guide for installing Groovymame  .
Everything was installed without problems.
I use an dvi-i port , so with an dvi-i cable to vga - > into the usma scart adapter -> scart to tv .
i also see that that EDID emulation is detecting Output:  Digital_7 DVI-i enabled - GENERIC_15
But i do have one problem unfortunetely i get an triple screen display on the crt
Any help appriciated
Moksi
Re: Triple screen crt display with Groovymame install
« Reply #1 on: October 23, 2021, 06:04:49 am »
settings in video mode
Calamity
  • Moderator
  • Online Online
  • Last login:Today at 05:51:32 am
  • Quote me with care
« Reply #2 on: October 23, 2021, 07:14:01 am »
Don't select an output labelled as "Digital" for EDID emulation, it won't work, select the one named "VGA" if it exists (it should).
Steps to create a log:
Moksi
« Reply #3 on: October 23, 2021, 11:28:11 am »
Yes i had someone helping me out its solved now , the device i set to generic pnp , output set to analog vga. removing the lcd hdmi connected to the gpu
It works
Moksi
« Reply #4 on: October 24, 2021, 07:00:04 am »
thx
« Last Edit: October 24, 2021, 04:05:33 pm by Moksi »
