Author Topic: Meaning of CRT Range values and defining modelines in Arcade OSD  (Read 3307 times)
BigBoss1964
  • Last login:August 06, 2021, 07:44:56 pm
Hi dears
First of all a million thanks to Calamity et. al. for the brilliant CRT Emudriver. Its a dream come true.   :applaud:
I wanted to ask the meaning of some of the parameters in CRT Range. i.e. what difference to the geometry they make. I know a couple but not the rest.
crt_range0
HfreqMin-HfreqMax, VfreqMin-VfreqMax, HFP, HSP, HBP, VFP, VSP, VBP, HPol, VPol, PLMin, PLMax, ILMin, ILMax
HFP -- horizontal front porch
HSP -- horizontal sync pulse
HBP -- horizontal back porch    (I believe used to move the screen horizontally)
VFP -- vertical front porch
VSP -- vertical sync pulse
VBP -- vertical back porch       (I believe used to move screen vertically)
HPol -- horizontal sync. polarity
VPol -- vertical sync. polarity
Can you guys please let me know what these other values do in terms of geometry. Is there any option to "shrink" or "expand" the screen vertically or horizontally or the whole displayed area/frame.
Secondly, is there a way to add modelines to arcade OSD without having to generate/install them through VMM. As this overwrites all the fine geometry adjustments I have made for modelines in Arcade OSD.  :banghead:  :(
I can usually add a resolution to "user - super resolutions.ini" but Arcade OSD doesn't see it unless I use the "install modes" function in VMM.
Many thanks in advance!   :laugh:
« Last Edit: July 04, 2021, 12:38:04 pm by BigBoss1964 »
