Author Topic: CRT Emudriver - Non emulated compatible games  (Read 228304 times)
tisurame
  • Last login:August 03, 2025, 10:50:53 am
Re: CRT Emudriver - Non emulated compatible games
« Reply #320 on: December 29, 2024, 07:02:23 am »
UFO 50
Steam
Native resolution is 384x216
It works perfectly right from the start. No need to change any configuration inside the game.
Highly recommended, since it's 50 (very good) games.
« Last Edit: December 29, 2024, 07:04:22 am by tisurame »
tisurame
« Reply #321 on: January 03, 2025, 08:30:36 am »
Void Stranger
Steam
Native resolution is 224x144, but it's too low for the monitor, so I'm using 288x192. You need to set to windowed mode 1x.
Aspect ratio looks perfect on a 4:3 screen. No need to use the 16:9 mode of your monitor.
8bitGeneration
  • Last login:August 21, 2025, 08:01:49 pm
« Reply #322 on: May 16, 2025, 03:04:18 am »
The Takeover and DOUBLE DRAGON GAIDEN RISE OF THE DRAGONS resolution anyone?
Recapnation
  • Last login:May 16, 2025, 07:59:16 am
    • Eiusdemmodi
« Reply #323 on: May 16, 2025, 07:56:56 am »
Seems to be 1600 * 900 for Takeover:
DDG's design resolution is 384 * 216:
8bitGeneration
« Reply #324 on: May 17, 2025, 11:30:13 am »
Will try these, much love. Thanks!
« Last Edit: May 17, 2025, 11:32:01 am by 8bitGeneration »
BuckoA51
  • Last login:November 04, 2025, 08:57:40 am
« Reply #325 on: May 22, 2025, 08:19:39 am »
You can't just copy my script Verbatim.
You need to change the path to the exe file yourself..
Mine is located in
Code: [Select]
C:\Games\KAGE Shadow of the Ninja\KAGE Shadow of the Ninja.exe
Yes I know, I changed the path, doesn't work (as described).
Rion
  • Last login:December 09, 2025, 10:54:17 am
  • 240p, 480i
« Reply #326 on: June 04, 2025, 10:17:14 am »
Mine is located in
Code: [Select]
What is you path then?
8bitGeneration
« Reply #327 on: June 09, 2025, 05:44:32 pm »
NINJA GAIDEN: Ragebound Demo anyone?
phasermaniac
  • Last login:June 10, 2025, 09:39:41 am
« Reply #328 on: June 10, 2025, 09:39:41 am »
I would bet 480x270
CRTFTW
  • Last login:December 02, 2025, 02:23:08 pm
« Reply #329 on: July 07, 2025, 01:16:19 pm »
You can easily find out for yourself.
On a standard monitor:
In the game options, set it to the x1 window mode, where 1 pixel on your monitor is 1 pixel in game.
Run and inject Special K, open the OSD, read the window resolution.
That is the resolution of the game. Make that as a custom resolution
BuckoA51
« Reply #330 on: July 08, 2025, 12:31:29 pm »
Btw SkyRacket is listed as 384x216 but I just downloaded the demo and it's 480x270.
tisurame
« Reply #331 on: July 10, 2025, 10:46:24 pm »
Zexion
Steam
Native resolution is 320x224. It works perfectly.
Awesome metroid-like game.
grendelrt
  • Last login:July 31, 2025, 04:05:14 pm
« Reply #332 on: July 31, 2025, 03:10:14 pm »
Earthion looks to run at 320x224 being originally a genesis cart.
https://store.steampowered.com/app/3597580/Earthion/
Hunk_4TH
  • Last login:August 11, 2025, 07:03:04 pm
  • I DON'T ALLOW VANDALISM IN MY STOOOOOOOOOOORE!
« Reply #333 on: August 11, 2025, 07:03:04 pm »
Is there a command line to get Switchres to work with Duckstation, Pcsx2, and Dolphin? All standalone. I use Launchbox so I figured the command line could be added there. I'm new to Switchres outside of Retroarch.
8bitGeneration
« Reply #334 on: August 21, 2025, 08:01:49 pm »
I would bet 480x270
no NINJA GAIDEN - Ragebound is showing some bad pixels with that resolution like letters artifacts while moving etc...
I did that opened the game on my pc monitor and i switched the game to windowed also did Alt+Enter, Special K when accessing OSD with Ctrl+Shift+Backspace in resolutions it's not showing me the resolution that i should be using on the CRT TV, it's only showing the resolution of the window and what do you mean by set it to the x1 window mode in game options there is no such option in the game there is only windowed and it lets you choose a resolution, what did i miss?
Rion
  • 240p, 480i
« Reply #335 on: August 25, 2025, 03:27:04 am »
I would bet 480x270
Looks like its 854x480
50% downscaling would be 427x240
I haven't tried myself so its just guessing at this point.
Rion
  • 240p, 480i
« Reply #336 on: September 18, 2025, 04:21:10 pm »
Super Mario Bros Remastered
Super Mario Bros Remastered (GitHub)
256x240@60
