Author Topic: ROWE Ami CD 100 jukebox will not allow me to enter numbers to play, help  (Read 5988 times)
Mary Lou
  • Last login:August 18, 2019, 01:19:56 pm
I have replaced battery and did full initialization. Error code comes up 14-04. At one point I had message reading Priority 00. Cannot play CD
Ken Layton
  • Guru
  • Technician
14-04 indicates factory defaults are requested to be manually loaded.
Karetaker
  • Last login:July 28, 2022, 08:19:40 pm
Re: ROWE Ami CD 100 jukebox will not allow me to enter numbers to play, help
« Reply #2 on: September 09, 2019, 10:11:08 pm »
Put it into service mode with the service switch. Turn off power to the jukebox with the power switch. Hold down the 1 & 0 on the keypad. Turn the power switch back on and wait until the display reads defaults loaded. Then you can release the 1 & 0. You may have to initialize the CD's again.
